Engine break in secrets
Old Oct 31, 2004 | 02:07 PM
Mark V8's Avatar
Mark V8
Default Engine break in secrets
http://mototuneusa.com/break_in_secrets.htm
Scary way of running in a new engine
Mark
Old Oct 31, 2004 | 02:12 PM
Dilly's Avatar
Dilly
don't think i'd wanna try that out myself
Old Oct 31, 2004 | 02:19 PM
gurnE's Avatar
gurnE
A looser engine will of course give you more power.
At the expense of engine life tho!
Must admit I did run the cossie in gently as I cannot afford another rebuild
But my R1 was deliberately thrashed from the word go
Old Oct 31, 2004 | 02:22 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
mmmmm. Not too sure if thats the way i would like to run a new engines in.
Old Oct 31, 2004 | 02:43 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
dont fords just whack the new engines on a dyno n run em at 6k for like 30 mins or summit
Old Oct 31, 2004 | 02:45 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Its the way I ran shitloads of engines in on the dyno at work
And the way I shall be running in my own 2.1 Zetec soon as its got a running in map.....negligable boost but lots of WOT.
Old Oct 31, 2004 | 03:00 PM
Guinnless's Avatar
Guinnless
I'm glad to hear this. No running-in at 2000-rpm bollocks for you then
I was running to 6000rpm after 500 miles.
Old Oct 31, 2004 | 03:03 PM
markk's Avatar
markk
im glad that someone has written about this , ive used this method of runing in my engines for over 10 years , all my competition engines had been fully run in withtin 200 miles and run at full power and full reves within this and i have never had a failure because of this method , all this 1000miles is just bullshit to me !!! at last !!!
Old Oct 31, 2004 | 03:30 PM
Kev.H's Avatar
Kev.H
ive heard of this before off a mates dad when he re built his xflow for a mk1 was never really sure if he was kidding cool info
Old Oct 31, 2004 | 03:43 PM
Mark V8's Avatar
Mark V8
I managed to glaze the bores on a freshly built V8 just by running the cam in at around 3000 rpm with no load
It is so hard to make yourself give it some load and RPM when you've just blown a years overtime money on a rebuild and don't want any harm to come to your new creation.
Mark
Old Oct 31, 2004 | 05:17 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
i ran mine steady for about 10 miles then gave it plenty of WOT it was been mapped @ 400miles it uses no oil at all and has no breather system yet
Rs Gus's Avatar
Rs Gus
i also ran it in on greys
Old Oct 31, 2004 | 05:35 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I can't open the link
I have always wondered how you are supposed to run an engine in when you have fitted new Pistons/Rings and a new Cam and a new Turbo.
The engine really wants some gentle miles, as does the turbo, but the cam guidelines tell you to run it at 3000rpm for 20 mins or something??
Old Oct 31, 2004 | 05:40 PM
Guinnless's Avatar
Guinnless
No gentle miles for anything! CVH cams must not be allowed to idle for the first twenty minutes.
Remember it's a machine not a bairn.
Old Oct 31, 2004 | 05:47 PM
Rhys's Avatar
Rhys
fook that after blowing loads of G's im taking its stdy. He talking about race engines though? if so wold the engine life be comprimised?
Old Oct 31, 2004 | 05:54 PM
markk's Avatar
markk
Rs Gus,
Old Oct 31, 2004 | 06:38 PM
Rs Gus's Avatar
Rs Gus
Originally Posted by markk
Rs Gus,
and i also kill it daily on greys
Old Nov 1, 2004 | 07:19 AM
Daveyraveygravy's Avatar
Daveyraveygravy
I work at Ford Dagenham Engine Plant in the Engine Evaluation department, all we do when we dyno the engines is warm them up a bit then we set them off on there tests.
There are max RPM no load cycles but i don't think they are for long, a couple of minuites if that.
Old Nov 1, 2004 | 11:45 AM
Matt's Avatar
Matt
LOL people are so scared of running things in at times
markk, spot on
i ran mine it at 1 bar boost (on greys) using the rev range and WOT more progressively with the miles, it was mapped to 2 bar boost after a month having done about 500 miles and then hit the rollers a week later.......... as recommended by a certain engine designer/builder/mapper i know rather well and trust
its now done about 3500 miles, uses less oil (mineral i might add - no synthetics required ) than a std cossie
Old Nov 1, 2004 | 12:46 PM
Ian2wdsaffcos's Avatar
Ian2wdsaffcos
So less than 1litre per 500 miles then!
Old Nov 1, 2004 | 12:56 PM
JAP CRAP's Avatar
JAP CRAP
I was actually told this buy my girlfiends, best mate's dad, lol, who owns A1 gearboxes.
I have taken it very steady running mine in. but once I got to 800 miles I was told about this, that it needs load etc so I have been using some boost up through the gears occasionally. Still couldnt thrash it though. just too scared!! not without at least changing the oil first!
Old Nov 1, 2004 | 01:03 PM
Dilly's Avatar
Dilly
run mine in fairly easy and it don't burn any oil in between oil changes
Old Nov 1, 2004 | 04:23 PM
markk's Avatar
markk
Matt,
couldnt argue with that m8
exactly as i do
Old Nov 1, 2004 | 04:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Taking it steady does more harm than good if you taking it REALLY steady, youl just glaze the bores.
I remember a certain high power cossie engine that was "run in" for 1000miles really really steady and was burning a fair bit of oil. It happened to go down Bluesprint the same day i was picking up my car from there.
Joe took a plug out n got the microscope thing to look at the bore, saw it was all glazed and goes il fix that, and drives off in the car.
For next 10mins all you hear is the sound of a cossie beaing ragged to fuck around the countryside and a quite worried looking owner.
Car comes back, bores deglazed, no more smoke, car spot on
Ive always ran the cars in for 1000miles, upto 3k for a few hundred but lots of WOT, and then every 1000miles after go up a 1000rpm until 1000miles when im fully caning the car (not full boost tho till 1000miles).
By looks of this i was still taking it too easy!
New tactics for when the GTR is ready then
Old Nov 1, 2004 | 05:14 PM
gurnE's Avatar
gurnE
markk, spot on
Pretty much exactly what I did with mine and it doesn't use any noticeable oil
Not like the litre every 400 miles before the rebuild
Old Nov 1, 2004 | 05:20 PM
ImaRacing 700's Avatar
ImaRacing 700
Well i just run it in for 800miles then full boost.
I was told by a certain tuner you only need 200miles but its easier said than done when its a newly built engine and its well known that around a 1000miles is what is mostly said....
I am sure Dels (turbosystem car) was run in for nearly 2000miles???
Oct 9, 2015 07:38 PM
cos4ever
Ford Escort RS Cosworth
Aug 26, 2015 10:05 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
Churtz
Aug 3, 2015 08:19 PM
