General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
my secs monitor & pectel monitor are coming up with an intermitent fault on the ACT sensor
i have checked pin 31 in the hairbrush plug and wires seem fine & i have removed the rubber boot from the act loom plug and they seem fine as well, so what is the chance of the sensor failing and going open circuit as that seems to be what is happening as the secs monitor comes up "
act sensor failure, out of range -40deg"
and pectel monitor reads 77deg
and ideas as i dont want to have to remove the whole loom
didnt think so but would the sensor failure be likely to show open circuit and give these readings do you think? spose replacing it is a cheap simple thing to try before i have to remove the loom to trace the fault
About 25 mins drive from you in Stortford if your desperate mate.
Stu
may come and see you tommorow then mate, as im dropping the car off tommorow afternoon for the week for more suspension trickery so will be my last chance to try it before next weekend.
Mark, Im at home all day so feel free to pop up. Can take the westy for a sping too if you like.
Ive got spare Air, Water and thottle position sensors so can get it sorted.
it was the act sensor itself that had started to fail intermitently, fitted a new 1 and had the car on the rollers today for a few hours sorting my surge issue's and the sensor didnt show any faults at all.
