PassionRover 1.8 VVT cam timing?
head gasket went on my mates Rover 220 coupe, can't seam to find a Haynes for this model so before i take it apart does anyone know any links to were i can find info on this engine including torque setting, timing etc etc.
just the same as a normal k series iirc, except you have the other belt on the other end to change. just remove one of the cam sprockets, pop the belt on and put it back on the cam.
Just found the Torque settings aswell ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Engine
Nm Lb/ft
Camshaft cover bolts 9 7
Camshaft gear bolt
8mm bolt
10mm bolt
33
65
24
48
Crankshaft pulley bolt 205 151
Cylinder head bolts
tighten progressively
1st stage
2nd stage
3rd stage
20
180 degrees
180 degrees
15
180 degrees
180 degrees
Flywheel to crankshaft bolks 85 63
Oil Pressure switch 12 9
Sump bolts 10 7
Sump to gearbox bolts 45 33
Sump drain plug 25 18
Tensioner pulley backplate bolt 10 7
Tensioner pulley Allen screw 45 33
Timing belt, front top cover 9 7
Timing belt, front lower cover 9 7
Timing belt, rear cover to coolant pump 10 7
Scuse the poor formatting!
Engine
Nm Lb/ft
Camshaft gear bolt
8mm bolt
10mm bolt
33
65
24
48
Cylinder head bolts
1st stage
2nd stage
3rd stage
20
180 degrees
180 degrees
15
180 degrees
180 degrees
Sump bolts 10 7
Where do all the timing marks have to be before i take the head off?
What to look out for?
Any tips will help martin
Pics and link will help also
Hello.............are you an ex ZSOC member too?
*edit* Aha, just seen your email address - Matt "Windup Merchant" RS1600i.
How you doing mate?
How you doing mate?
Yeah, been trying to punt it off and come back to the blue oval (fancy something with a turbo these days
) but no success as yet. ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
You still running the ZS?
