Can anyone recommend a CAD package?
Can anyone on here use autocad or similar 3D design software?
What do people recomend?
Where can I get a copy from?
Austen
Austen
i've used both solidworks, autodesk inventor and catia. found inventor the easiest to use of the 3, but all are rather user friendly, and you can import autocad drawings into most 3d packages these days.
as for getting hold, i've only been able to get hold of student copies from uni, and they only have 2 year licenses. probably a few dodgy copies going about
Twistin me melon man
i use autocad, archicad, and MicroGDS. i would say autocad is the easiest to pick up. but archicad is by far the better software for 3d, modelling, rendering, and drawing register co-ordination.
How much is a good cad program? We dont really use that kinda thing as we work real world!
but we starting to get more jobs with CAD drawings to follow, Been about 10years since I worked with autocad!!!
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Autocad is the easiest to use and get hold of. Its around Ł475 for a proper copy but plenty of dodgy copies around.
I use Tekla 3D modelling. Its around Ł12k plus Ł2k a year maintenance and is impossible to copy
when i priced it up last year AutoCAD LT was Ł750 (inc vat) but thats just the basic 2D program with no 3D facility.
the full version is about Ł4000 including VAT.
If your looking for a copy, I have a dodgy copy here, that I could copy and send you.
Originally Posted by GARETH T
i have heard of dodgy copys of solid works are on torrent sites
They go all out to stop you getting pirate copies. There are plenty of ways round it if you know what you're doing, but I know a lot of people spend hours downloading only for it to be useless
Happily retired
Still use Autocad 2002 on my home computer all I require now im retired.
Still good for 2D & such an easy package to use.
For 2D home use AutoCAD LT
For 3D we use solid works but I guess a proper copy is a bit dear for home
AutoCAD is pretty much the bench mark, still the best IMO.
If you buy a genuine copy and subscribe most dealers will give you upgrades there after for free. We bought 2006 at work and have received 2007 + 2008 for nothing!
I'm a Civil Design Engineer
We got some design engineers in the house then?!
ben
ben
depends on what you want to do. for 3d illustrations you cant beat sketch up. its free, dead easy and quite clever. If you want the facility to create production drawings or machine input data then one of the more complex packages will be required, If you just want to create 2d drawings you cant beat Autocad however if you want a 3D design tool for complex shapes you need to step up another notch of programme, microstation. I use Autocad 2008, Microstation V8, sketchup and a pencil in my everyday work. Use the easiest tool for the job, not the most complex.
Cheers,
Justin P
Cheers,
Justin P
STOP!... Carry on
solidworks all the way IMO! used autocad and ddnt really get on with it too much, and the 3d stuff aint too good... never used inventor too much, but its meant to be good.
i used solidworks to create centrifuge decanters, it allowed you to modify and regen the assembly, it would then show you any interferences, plus the "cosmos" application can show you the flow fo water and air for any restrictions.
If you're drawing in 2D AutoCad is very good, but for 3D stuff we use Solidworks.
The info we get at work now all seems to come as 3D models in the form of IGES files so we end up using Solidworks to produce 2D drawings with all the sections required then export it as a DWG file as Autocad is much nicer to use in 2D.
Mark
Mark
Use AutoCAD 2006 at home and 2007 at work but do mainly 2D stuff - very easy to get to grips with if you have used a CAD package of one sort or another...
Certainly better and far more user friendly than Architectural Desktop (I think) that I used to create a 3D model for college, that was a pain in the @rse package
Indyrs
04-12-2022 12:39 PM
