FAO Builders or those in the know
Old 18-01-2008, 02:16 PM
dvid
dvid's Avatar
Default FAO Builders or those in the know
Hi all
I want to extend one side of our downstairs kidderminster (toilet for none bottom fans ) to add a shower, but I think both side walls are supporting walls, how easy (if possible at all) is it to knock done one wall in order to extend?
Thanks
Dave
Old 18-01-2008, 02:20 PM
SNP
SNP's Avatar
Depends on budget mate.
Sorry am a bit vague, but without seeing the property or what is supported from the supposed load bearing walls its hard to give advice.
Chances are its a simple case making sure you support the structure above with some steelwork.
Old 18-01-2008, 03:22 PM
vernam616
vernam616's Avatar
not hard at all really mate, i arnt a builder but im a electrician so im in the trade, and seen things like this done, all you have to do is get some "Akros" long metal stands to support either side of the celing, knock your wall out and stick a lintil in,
Old 18-01-2008, 03:23 PM
SNP
SNP's Avatar
He's basically correct, but if it as a mjor load supporting weall your removing, I'd not want to only support the structure above with a Lintel
You'd end up with some 203 x 102 UB's i'd guess?
Old 18-01-2008, 03:26 PM
Cowboi
Cowboi's Avatar
wedge it up with a broom stick or something mate, u'll be sweet
Old 18-01-2008, 04:16 PM
tomhs123
tomhs123's Avatar
as said above, you need to make sure that you have structural support in place before you anything, probly best to use Akros, then depending on whether they are load bearing or not you can introduce some sort of lintel.
Old 19-01-2008, 11:12 AM
dvid
dvid's Avatar
Akros?
Thanks for the replies, I won't be doing it myself, I'll be leaving it to the professionals, I was just curious as to whether it could be done
Old 21-01-2008, 10:35 AM
dvid
dvid's Avatar
Old 21-01-2008, 11:46 AM
dojj
Resident Wrestling Legend
dojj's Avatar
whats wrong with sticking a hose pipe out the toilet window and using that a shower?
think of the money you'd be saving and not having to bugger about with lentils and other bothersome vegetarians
Disabled Account
14
25-10-2005 06:55 AM
BillyCabrio
32
25-06-2005 02:23 PM
Disabled Account
14-06-2005 06:17 PM
61
24-03-2005 09:11 AM
Azrael
17-02-2005 09:26 AM
Quick Reply: FAO Builders or those in the know
