multilayer head gasket/long stud
Old 28-12-2007, 03:44 PM
col cos1
col cos1's Avatar
Default multilayer head gasket/long stud
i run a cometic 3 layer gasket just now with no issuesalthough i did first time round with them
doesanyone run/rate the 4 layer cometic?
also i long studded my 200 block with mountune 6
but just incase theres issues with them when i remove head
are arp ones ok to go for stick to mouuntune?
i just remember having 4 arp head bolts to go in place of the standard ones when building engine but was advised against them due to cracking block/head cant remember
any views appreciated
Old 28-12-2007, 03:47 PM
NEIL A
NEIL A's Avatar
From what i have heard there are better long studs than the mountune ones, as they seem to stretch at different rates.
Old 28-12-2007, 03:48 PM
col cos1
col cos1's Avatar
called what neil?
Old 28-12-2007, 03:56 PM
NEIL A
NEIL A's Avatar
Ask alan he got mine through a contact of Mike R i think.
Im sure Martin said he can get good studs aswell.
Old 28-12-2007, 03:59 PM
STUCOS
STUCOS's Avatar
Col when using 6 long studs,you are ment to use standard used head bolts in the other 4 holes
cheeRS stu
Old 28-12-2007, 05:01 PM
col cos1
col cos1's Avatar
cheeRS stu
i did but used brand new ones stu
surely once they ve been stretched you only get once shot at them no?
Old 28-12-2007, 05:09 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
mine is decked n skimmed and i use a mountune 3 layer steel gasket.....6 long stud all supplied by Ahmed,the 4 other bolts are old used jobbies........
Old 28-12-2007, 05:50 PM
ARP make fasteners/studs/bolts for a living, they don't make rubbish, but it is rubbish to think that a stud is ever going to be strong enough to break a block, if the block were that weak just starting it up would blow it apart with compression.
Idiots who try to force studs, bolts into holes are the likely cause of block cracking, some don't even tap the holes to get congealed oil/crap out before rebuilds.
Old 28-12-2007, 05:54 PM
STUCOS
STUCOS's Avatar
You use sh bolts in the corners,as they have already stretched,and shouldnt stretch any more,there fore stopping the head from lifting at corners,or so im tld any way
cheeRS stu
Old 28-12-2007, 06:17 PM
rapidcossie
rapidcossie's Avatar
Mountune one are fine until 450 ATW ish col.
Speak to Alan or Mike if you want something better
Not sure what they are called but they come from Scandanavia somewhere.
Old 28-12-2007, 06:22 PM
pete mcrash
................paper or steel....(dont know if they do paper )...................cos steel,ur joking
Old 28-12-2007, 09:14 PM
rapidcossie
Im talking about the long studs, so its steel
Old 29-12-2007, 03:23 PM
col cos1
col cos1's Avatar
cheers for replies guys
dont think il be breaching 450@ wheels
any time soon
anyone tell me anything about the cometic gaskets?
Cosnada
07-01-2016 05:30 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
Quick Reply: multilayer head gasket/long stud
