launch control buttons
Old Dec 25, 2007 | 03:15 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Default launch control buttons
where have you put yours? get your pics up. thinking of modding my gear knob but need some different ideas
Old Dec 25, 2007 | 03:23 PM
leecavturbo's Avatar
leecavturbo
pics of a switch
Old Dec 25, 2007 | 06:46 PM
Mark Shead's Avatar
Mark Shead
Default Re: launch control buttons
If you add a wheel speed sensor to it then you can have launch control permantly on as it will only work below a certain road speed, You can also add a switch also to this to turn off, or have a button that you press and hold for launch.
Mark
Old Dec 25, 2007 | 06:51 PM
angel45's Avatar
angel45
replaced the horn on the sterring wheel with mine
Old Dec 25, 2007 | 07:09 PM
NEEDFORSPEED
Mark
brilliant ive used a sensor of an xr2i 16v that goes on the speedo cable. tested it this morning whenb i powered up ecu testing everything and works spot on so that answeres that! well impressed with the autronic btw! thanks!
Old Dec 25, 2007 | 07:11 PM
Mark Shead's Avatar
Mark Shead
Mark
If its hall effect then it can be wired in no problems, Use HSI3 for the road speed input.
Mark
Old Dec 25, 2007 | 08:34 PM
NEEDFORSPEED
Mark
Mark
yep done that already just have to play with the wheel revolutions to get it right.one less thing to worry about then. il just use a switch for on/off
Batt Voltage Dwell time
8 Volt 7 ms
10Volt 5.5 ms
12 Volt 4.5 ms
14 Volt 4.0 ms
16 Volt 3.0 ms
does that sound right to you for coils? got it off a guy on the bba remon site he said that should be fine?
Old Dec 25, 2007 | 08:37 PM
darryl turbo's Avatar
darryl turbo
my dad's launch control button is next to the handbrake and linked to the handbrake
so once you put the handbrake down it goes
Old Dec 25, 2007 | 08:54 PM
EIL132's Avatar
EIL132
Put mine on the steering wheel.
Old Dec 26, 2007 | 06:19 PM
Mark Shead's Avatar
Mark Shead
Mark
Mark
8 Volt 7 ms
10Volt 5.5 ms
12 Volt 4.5 ms
14 Volt 4.0 ms
16 Volt 3.0 ms
You realy need the manufactors settings for them as coilscan vary a Skyline only runs 1.8ms at 14v.
Mark
Old Dec 26, 2007 | 06:25 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
mate dunno if you can see the red button on mine mark fitted mine up with it and i mounted it there, can be reached perfect when in first gear!!!
Old Dec 26, 2007 | 10:33 PM
NEEDFORSPEED
that looks good cheers! on the loom ive made i was going to use the launch button as hold to set but now marks said i can use the speed sensor (which i should of realised) i will just use it as on/off the same as the nos and water injection etc. easier i think. looks good there tho!! take it your running autronic or similar? really seems to be a good bit of kit! and very user friendly!!
Old Dec 26, 2007 | 10:38 PM
xrsi's Avatar
xrsi
got the sparco steering wheel mounted push buttons for mine, one is going to be for launch control other for nos or co2 spray onto intercooler (i know co2 getting into inlet isnt great as well before anyone says that)
Old Dec 26, 2007 | 10:45 PM
NEEDFORSPEED
i know befofe the arguements start lol. dont think it matters too much on idle at pod on a red hot day if a bits sucked in! if i dont sort my charge cooler setup il be using it for sure!! do you know anyone thats used the spray bar before?? temp differences/how long etc? something id like to look into as i want to do 1/4 mile mainly
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
