97 Escort rear wheel bearing replacement
Old 23-11-2007, 10:56 AM
Dan Si
Dan Si's Avatar
Default 97 Escort rear wheel bearing replacement
To remove the old bearing can I use a hammer and screwdriver and put the new one back in using a mallet like I did on my Corsa? Or does it need to be pressed?
Dan
Old 23-11-2007, 07:34 PM
djmillsy
Fife Radge
djmillsy's Avatar
you should be able to do it like a corsa one i did mate
Old 24-11-2007, 05:39 PM
Received 1,044 Likes on 998 Posts
Easy to do mate just use a good screwdiver or a chisel and knock the old bearings out. Use some sockets to refit the new bearings.
Old 24-11-2007, 06:09 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
thats how i do it mate, put the drum in a vice and twat it out with a punch.
to refit, i use the old bearings to drive them back in (need to tap them out a little bit again, but i find its the best way)
Old 26-11-2007, 10:28 AM
Dan Si
Dan Si's Avatar
Cheers guys I did it Friday afternoon. I finally bought a Haynes when I got the bearing. Used a piece of metel between the oil seal and the mallet.
I'm chuffed I saved some money on labour and the problem is cured.
Old 09-01-2010, 11:40 AM
jackl86
jackl86's Avatar
thank god i found this thread lol jus got a quote of £300 to do the bearings on mine! of to halfords i go
Vincereese
01-06-2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
malkiemac3579
14-07-2017 12:10 PM
Vincereese
16-08-2015 06:38 PM
muz
01-08-2015 06:48 AM
Quick Reply: 97 Escort rear wheel bearing replacement
