Best way to remove seized plugs?
Tried soaking with WD40 but no luck, have cracked one of them trying to get it out with a Bar as well
On a fiesta 1.1 Engine.
Any ideas?
Any ideas?
Ah.. ill try that, Ive got an impact gun, didnt think of that.
my neighbour suggested pouring my can of Coke round them and leaving it for a Bit
Passion for Fords!
ive done a few of them for garages around this area, i always end up taking the top off the plugs, and battleship welding a nut onto them...the combination of heat and a big nut normally gets them out, well it hasnt failed yet!
very very common problem with this engine btw...make sure you use heaps of copper grease afterwards.
If all else fails im going to crack the top off and hammer on a slightly smaller socket and get the big bar out to try and break them free.
Passion for Fords!
wont work ive been there...... another thing you need to watch out for is if you smash the internals of the plug the electrode will fall into the combustion chamber, so it would be head off anyway, be carefull!
and if the nut part of the plug breaks off it will leave the thread in the head, heat is what you need to break the corrosion seal that has been formed, sometimes even runing the engine for 30mins before can help....
Originally Posted by Chip-3Door
get the big bar on them, and just make sure you dont drop any bits down the bore, so crack them off first by half a turn, then get clearing up the mess before you pull them out.
Passion for Fords!
the welding a nut idea works. and you need the metal part of the plug in place and not snapped off to do it get it cherry red with the mig, count to ten and undo it.
if ya stick the bar on it and snap it off you havent got a choice then...
only speaking from personal experience here if i had a penny and all that
fookin cast iron heads eh
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
Fudgey
17-09-2015 01:06 PM
