gearbox question
Old Aug 14, 2007 | 03:36 PM
D-Sport's Avatar
D-Sport
Default gearbox question
i may be a little out of order but........................
i recently sent my gearbox in because i was getting different wheel speeds on the dyna pack,
firstly i got a bill for 3 grand, when i questioned this i was told that they wanted to replace everything, i asked why and was it absolutely nessecary and he replied no, i asked about the wheel speed difference and he said the vc was fooked, i said to him to replace the bearings as he was in there at it but to leave everything else alone and to repair the vc
now heres my annoyance
the origonal quote to replace everything included 280 plus vat to cover the labour for the strip and rebuild, however having not replaced any layshaft or gears etc the labour cost remains at 280 plus vat
i rang and asked why the labour cost was the same and the reply i got was "i took it to pieces and put it back together so the cost is the same regardless of whether im replacing the shafts and gears or just putting back all your origonal shafts and gears
opinions?
am i being too hard expecting a lower labour charge
d
Old Aug 14, 2007 | 08:47 PM
D-Sport's Avatar
D-Sport
24 views and 0 opinions?
Old Aug 14, 2007 | 08:49 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i kind of agree with him to be fair, it takes the same amount of time to fit new parts, as it does to refit your original parts.
what box is it?? 3grand is a lot of dosh
Old Aug 14, 2007 | 08:50 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Well he's doing the same job wether he replaces new parts or not, so its still the exact same time labour wise new parts or not.
Old Aug 14, 2007 | 08:54 PM
Dan's Avatar
Dan
3 grand! What fookin box is it for that?
Old Aug 14, 2007 | 09:22 PM
dojj's Avatar
dojj
Resident Wrestling Legend
i'm assuming it's a 4wd car and assuming it's a MT75
in which case, you don't neccesarily need to strip the whole box down to change the VC but if there was anything else wrong with it and he didn't take the box apart and it went bang, he'd be facing a rebuild out of his own pocket, so he's taken it apart to make sure, and it's not a over the top labour charge for the job
mind you, i don't know where you went to get it sorted, but i've had boxes rebuilt for half that and with new bits in but it's mates rates etc so it's not a big deal
the £3k though, thats what you need to be asking yourself about
Old Aug 15, 2007 | 08:30 AM
D-Sport's Avatar
D-Sport
the 3 k was for him to basically take out every single bit of the internals and replace em all with new bits, something which i never asked him to do, when i got the estimate i rang and asked what the fook , when he told me that my own stuff wasnt going to calf (fall apart) over the next 12 months i told him to leave well enough alone, i only sent it in because of getting different wheel speeds on the dyna pack to which he replied that it was the viscous coupling was fooked and was causing the wheel speed difference,
so my point was 280 quid labour on top of 280 quid to do the viscous, fair enough he had a look inside perhaps and checked the gears etc but he wasnt asked to do that
dunno maybe i am being over the top
Old Aug 15, 2007 | 09:32 AM
dojj's Avatar
dojj
labour is a bit harsh but still........
parts are a bit expensive unless he's done the chain as well
Old Aug 15, 2007 | 11:33 AM
ballin's Avatar
ballin
he's right imo
Old Aug 15, 2007 | 11:38 AM
GUZZLER's Avatar
GUZZLER
why take the box apart if it only needed a v.c. ???
to change the v.c. you don't even have to remove the box
Old Aug 15, 2007 | 12:19 PM
dojj's Avatar
dojj
i think the assumption here is that the owner has taken the box/car to the gearbox place to find out what's wrong and they have removed the box, which might also explain why the labour rate is higher than just replacement of the rear casing
Old Aug 15, 2007 | 01:02 PM
xr4x4rs's Avatar
xr4x4rs
for 3k you could of a had a proper strong gearbox, with all new gears, uprated vc aswell
Old Aug 15, 2007 | 02:47 PM
foreigneRS's Avatar
foreigneRS
Testing the future
can't fully understand it all, but don't think he has paid £3k - that was an estimate to replace all parts that he didn't ask to be done but that the gearbox place recomended
Old Aug 15, 2007 | 02:59 PM
ballin's Avatar
ballin
correct, read the post people
Old Aug 15, 2007 | 04:25 PM
D-Sport's Avatar
D-Sport
it was just the box that was delivered to the place and the question that was asked of them was why was the wheel speeds different on the dyna pack, can you investigate why and put right
i havent paid the 3 k cost nor wouldnt, when i questioned the 3 k price and told them to just fix the wheel speed problem i was in formed that it was the vc was causing the wheel speed problem,
my point to him afterwards was, " you asked for 280 quid labour to strip and rebuild the gearbox but all you have done is repair the vc, he says he crack tested all the parts inside it when i told him i didnt want to spend 3k on new layshafts, new gears etc
so in essence, 280 to strip and rebuild using new parts for labour or 280 for fixing the vc and looking inside which he wasnt asked to do,
incidently the vc cost an extra 280 to fix outside of the 280 being charged for labour in terms of replacing all the internals of the box
Old Aug 15, 2007 | 04:26 PM
abdr500's Avatar
abdr500
let me gess gearbox man
Old Aug 15, 2007 | 05:13 PM
dojj's Avatar
dojj
so you've told him that it's got different speeds front and rear and to find out why
the firs thing anyone would do if they knew what the boxes are like would be to change the viscous, or at least test it out and then report back any findings
i don't know who you used because you haven't said, but it looks to me like there is an extra £280 in there for stuff you didn't actually ask him to do, nor did he get authority to do without asking you about pulling the box apart
in which case, yes, you are right to bee mightly pissed off and getting charged extra
does the box look like it's been apart?
Old Aug 15, 2007 | 05:48 PM
D-Sport's Avatar
D-Sport
i dont know if the box has anything done to it as im in ireland and wouldnt be released to the courier until i had paid in full, it wasnt gearbox man and i dont want to liable myself by saying who it was yet, its on its way back and i suppose time will tell
i wouldnt mind paying a bit for a guy to give it a once over but i do feel a little sore around the chocolate starfish if you get my meaning
Old Aug 16, 2007 | 09:46 AM
dojj's Avatar
dojj
then mate, you look like you've been stuffed
wait until it comes back, if it's all clean and tidy and shows signs of being pulled apart then at least he's done what he's said he has done
if not, make sure you paid by credit card and let them expensive banking type lawyers loose on him
Old Aug 16, 2007 | 11:43 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
would you have felt better if instead of them having a fixed price for labour to strip and rebuild a box they had two prices 280 to strip and repair 380 to strip and repair and fit new parts.
Most gearbox companies have a similar price for the mt75 when it come to labour charges.Quaife charge 300 labour plus carriage plus vat to fit their 3k gear kit, we have a similar price for that. seems fair to me to charge that labour fee to strip check and rebuild your box.
the suggestion of 3 k to fit all new standard parts was not the correct advice on an mt75,unless of course the owner wanted all new standard parts and not a straight cut.
The standard mt75 gearbox is not any good for any more than standard bhp
Old Sep 4, 2007 | 09:31 AM
D-Sport's Avatar
D-Sport
well im back again,
we found out at the weekend when trying to fit the propshaft that the fucking twats have fitted the piece in the gearbox where the prop slides into.............................................. ...........THE WRONG WAY AROUND
WHAT A PACK OF FUCKWITS
Old Sep 4, 2007 | 09:35 AM
Disabled Account's Avatar
Disabled Account
well im back again,
we found out at the weekend when trying to fit the propshaft that the fucking twats have fitted the piece in the gearbox where the prop slides into.............................................. ...........THE WRONG WAY AROUND WHAT A PACK OF FUCKWITS
Sorry to hear that................To be fair it's a mistake that a gearbox builder will usually only make ONCE in a lifetime. That splined front prop output is designed badly as it fits perfectly either way round.
Old Sep 4, 2007 | 09:40 AM
D-Sport's Avatar
D-Sport
THE ANNOYING PART ABOUT THE COONTS IS WHEN YOU RING YOU ALWAYS GET "OH HES ON HOLIDAYS"
Old Sep 4, 2007 | 09:44 AM
Disabled Account
Whereabouts are you?
As only the rear part of the transfer box has to be removed and then re-fitted/sealed, it's actually a 10 - 15 min job for someone that has dismantled an MT75 box before.
Old Sep 4, 2007 | 09:51 AM
D-Sport's Avatar
D-Sport
im in ireland but the car is in the uk with a mate of mine / tuner , its those coonts in r and d, fucking shite service, they think cos your across the pond that they dont have to return your calls
Old Sep 4, 2007 | 09:55 AM
Disabled Account
Well, tell your mate/tuner to take the gearbox to Bara Motorsport (Bromsgrove, Worcs.), phone Bara first and tell him what needs doing - he may well sort it while your mate/tuner waits there: 01527 880011
Old Sep 4, 2007 | 09:57 AM
D-Sport's Avatar
D-Sport
thats very good of you , does he specialise in those boxes??
Old Sep 4, 2007 | 10:00 AM
Disabled Account
Yes, he would apear to know what he's doing when working on MT75 boxes....
I dont think he works on the R & D boxes usually, BUT the transfer box is exaxtly the same anyway.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
