IAW I cant replay the log I just made during a drive !!
Anyone who can help.. explain what I may be doing wrong.. please explain by LEGO´s
I click file in the logging "window" and I create a folder (think it is called), I also remember that I must log as "raw data" and I start both scope and logging. When taking a look in document I see my (lets call it a drivingsession) as a textfile... I tryed ALOT now.. and cant seem to have it replayed
I realy think I need this explained in.. "explanations for foreign dummies"
help.. please
help.. please
Hi Stewart...
Thank you alot.. I was getting completely insane cause I couldnt make it work!!! i will try and have a closer look at this textfile.
ehh.. would you be so kind to translate this "Pop your own headings on"
Spreadsheet is like word or so I guess
AWESOME piece of tool this IAW.. love it ...
Is it correct that your chip send out more info than mostly/all others to look at with this monitor??
Originally Posted by JanDK
Hi Stewart...
The first for example is normally RPM, so if you make a mental note, or even change teh top line to read RPM, the columns will soon make perfect sense as you work through them.
Maybe paste your log into teh screen so we can see it, or screenshot it maybe better?
Testing the future
you can then easily make graphs to visually check the data
Great guys.. I took a closer look at the text.. I think I am getting it
I will give you a small briefer now.. then I will paste it in here so you can se it all!
I see water temp slowly rise... tops at 96 but when most warn (slow driving in the city at 25celsius and no fan caused of a defect tempswitch)
I se airtemp rise and fall slowly.. engine hot and still driving, it is as low as 20 celsius on standard IC.. and I just bought a large Pro Alloy!!!!!!
Batteri .. super condition
Its funny... hehe
I do need an explanation on Ĺmĺl-valve .. in % ??? what does it tell me
Status 1 & 2 ??
Its funny... hehe
Status 1 & 2 ??
Testing the future
Its funny... hehe
Status 1 & 2 ??
Its funny... hehe
Status 1 & 2 ??
boost control valve % - the valve is controlled by a 10Hz PWM duty cycle. it's not just an on/off solenoid valve, it is a proportional valve.
you should wait for stu to confirm this, as i may have it the wrong way around: the higher the PWM %, the more the valve opens and bleeds boost pressure from the compressor housing away from the actuator. that gives you more boost compared to if you just had the compressor housing connected directly to the actuator (at the same actuator pre-load and spring rate)
Just found out that inlet airlet air 20 deg. celsius was the morningdrive I looked at the wrong file... afternoondrive was about 35 peaks at 42 a few times!
I will be back with a log to have a look at.. hopefully soon
Hope so or I will cry BIG time
Another thing.....
I just wrote RP a Q..
I am trying to keep cool, but my laptop (ICP laptop ONLY) have been confliction ALOT since I had it. I had an "expert" clean it up an install new XP pro, before installing ICP , allthough I told him to check the size of the computer an make sure that it could handle it.... but now another real expert says that XP pro is KILLING the laptop!!!!!
Do you think I can change windows (maybe to W98) without having any trouble installing ICP once again??
Do you understand what I mean?
Another thing.....
Yes.. I know it is compatible.. but I am unsure that the securityprogram will stop me from change XPpro with ICP installed to Windows98 and then reinstall ICP... I am sure that this is possible as I dont see Windows as an important thing of my ID to ownership of ICP.
Testing the future
sorry, i understand what you mean now.
i'm not sure though. the security program generates a code based on the info in the compinfo.txt file that you send to RP Lab. i don't know if anything in there changes when you change your version of windows? for example, the username that you put in when you set up windows.
you could always try a dual boot system where you add win 98 to the existing XP OS and use the 98 for IAW Monitor and XP for other things (although you say the laptop is to be used only for IAW Monitor?)
Hello Jan,
Got your message - but since you've posted it here, I will answer in public.
No problem with Win98. Instal Win98, send me the security file and I will prepare licence information for you, so that you can continue using the product...
Hope that helps,
Nikola
Hope that helps,
Nikola
You DID understand my confused explanation
TPM961
15-01-2018 10:50 AM
