dry sump, wft ..
Baby Cheesus
a dry sump uses a very thin sump pan, the oil is then sucked out of this by a belt driven pump and pumped into a container elsewhere.
the oil is then sucked through the normal oil pump and around the engine, where it will again drain back into the sump and pumped into the container
so in effect, there is no mass of oil in the sump, its all stored seperatly.
reasons for this are to avoid oil surge/starving the engine of oil on race cars, or for space issues.
do a search for 'dry sump' on google, it should make you understand a bit better.
3 other benefits
allows much larger oil capacities due to remote storage tank - 2 gallons being the norm - good if the engine breathes heavily, endurance racing. Also helps reduce oil temps
a shallow sump also allows the engine to be sat lower in the car helping reduce CoG to help lower roll centres and CoG
less oil drag on the crank as it doesn't have to spin through a big puddle of oil like in a wet sump - ie reduction in parasitic loses.
Downsides being expense and extra weight in all the additional plumbing / tanks / pumps etc.
Originally Posted by BROM@ZOO
cost me around Ł3500 to do my whole car fuel and brake included
FOR SALE : Pace dry sump kit, as new, just needs pipework
tony
that was a customers sump mounted pump !!!!!!!!!!!
i got a 4 stage 4 rotor block mounted pump
2 sump scavenge
1 turbo scavenge
1 cam cover scavenge
and a 1 port check valve (pressure release)
oh and has the 2 stage pressure with 2 inlets to the wrc block
2 sump scavenge
1 turbo scavenge
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
tony
2 sump scavenge
1 turbo scavenge
2 sump scavenge
1 turbo scavenge
Also funny how your pump pulley sits in exactly the same place mine does too
![](https://img.photobucket.com/albums/0703/TonyRyan/ecus00032e.jpg)
i see if i have a new pic the pic on my engine in my car was the customers dummy engine when i did a rwd escort mrk 3
indeed the one in the pic was a sump mount but my new one is block mounted
WD - is that the Dax?
Any more pics?
Any more pics?
Long way to go with the build
![Content](https://passionford.com/forum/images/smilies/content.gif)
Basic spec is :
MC chassis with thick wall tubing, mounts to suit YB.
Dax RAC spec cage
CCAR front suspension.
T38 BD14 spec cossi lump (aiming for 450)
Car will be stripped - no screen etc, if it doesnt need it for SVA or MOT its not having it.
WD
tony
2 sump scavenge
1 turbo scavenge
2 sump scavenge
1 turbo scavenge
Although laymans terms would be better for me ...
I believe my pump is a four stage :
![](https://img.photobucket.com/albums/0903/Peter1/Dax%20Rush/21bf716c.jpg)
The extra will scavange the turbo and oil drain from the YBP separator. The separator has had the valve moded to seal on vacum but open under pressure. I have tee'd the turbo return with the separator as I was told it was possible to 'over scavange' the turbo ?
Whats the 2 stage pressure and inlets all about ?
Any of you got a good design for the crank sensor mount ? I have moved the timing lugs to a more suitable position :
![](https://img.photobucket.com/albums/0903/Peter1/Dax%20Rush/PulleyFront.jpg)
Cheers,
WD
![](https://img.photobucket.com/albums/0703/cozzybrom/drysump.jpg)
![](https://img.photobucket.com/albums/0703/cozzybrom/drysumppump.jpg)
![](https://img.photobucket.com/albums/0703/cozzybrom/drysumptank.jpg)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Fair play Brom.Its a good thing,thats worked well on your car...
Pete..
so when does the need to replace the oil pump (ie remove it) and use the dry sump to pump and scavange,
do oyu only do this when you exced the engine revs capacity of the standard pump, or for more flow???
has any body removed the standard pump and gone for this set up?
What size oil tank would you need for a 2.0 race engine?
If the tank was in the boot would that be bad? or does it have to be in the engine bay?
Pace say the closer the better but I cant really see how that makes much difference, maybe the pump just has to work a bit harder ?
I have the second (of four) pace tank sizes, cant remember it's size in L but it looks to be a bit smaller than broms
Brom you cheapskate with a 3 port pump , lol !
![](https://img.photobucket.com/albums/0703/TonyRyan/v00000e.jpg)
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
timsrs
22
24-09-2015 08:14 PM
