is my cossie engine scrap?????????
just took head off as gasket gone to find it only 137.5m so i belive it can not be skimmed again i got a crack in block across a bolt hole and i can move pistons about 2 mm side to side . i really am startin to get fed up with car as i only had it four manths and something all ways going wrong is this piston movement normal and i haeard long studding block can get round teh crack. also around the bores is wire rung does this need re doin or can i just slad an uprated gasket on top off groves
the was some one sayin the other day that if its a 200 block, and the crack isnt too deep it can be fixed but will be no good for a big power set up!!
as for the wire rings ,do not leave out ,they need putting back in...
i have just had my head gasket done ,and it was because the last monkey that did it left my rings out
if your gonna keep the car then i would get another engine, if your gonna punt it on then maybe you could have it repaird , to be honest all the work you need doin needs doin be a pro so yo may as well take it somewhere and see what tey say.
gary
gary
09-10-2015 07:38 PM
kosienutter
31
22-08-2015 09:55 AM
lockie
31-07-2015 10:03 PM
