General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I think it is above your feet, on the passenger side
It is there on a 2wd, but knowing Ford they moved it on the 4x4s (yellow one) .
Not this time, its above the feet, next to the transmission tunnel as Tabetha said.
You will probably find two yellow ones there, one is for the injectors and the other is for the pump. If I remember it correctly the one with the thick red wire is the pump relay.
Jesus I got one right this year!!
Why not wire into back off ignition switch ?
ps and wear your seatbelt next time you naughty boy!!, my lad dobbed on you
