MAPPERS.......(GOTECH)
Old 22-05-2007, 12:12 AM
  #41
NEWTON
NEWTON's Avatar
Originally Posted by Chip-3Door
Originally Posted by series_one_rst
thats not bad at all from a 1600. is it low comp?
if its detonating the engine set up (timing, temps etc) cant take the boost so doesn`t sound as if the turbo is giving up on ya.
If the turbo is struggling to flow more air at the top end then the only option Jamie would have left to try and eek every last bhp out of it would be to both gradually lean it out and increase more timing in a desperate big to increase the BHP per Lb of air.
So if the turbo was struggling at the top end it could easily do exactly what is described.
Also if its spinning its tits off it could be introducing a lot of heat that could lead to det as well.
Conversely it could be the head is too restrictive and causing the same effect.
It could also be that the exhaust side of the turbo is increasing pumping losses on the engine.
Basically, it could be lots of things with those symptoms, including the thing you say it cant be!
head carnt be to restrictive,the ports are massive did do big wheel spins on the rollers,chip do you know about turbos,ie if i got a gt30 what size exaust housing to go for
Old 22-05-2007, 12:17 AM
  #42
series_one_rst
series_one_rst's Avatar
standard comp on the 1.6 cvh turbo is 8.2:1/8.3:1 i belive mine is around 7.8:1 to allow more boost bit more laggy but higher pressures cuz the cylinders dont get as hot.
i`ve known 18 psi on standard comp with water injection not 22 on 8.5 with just a twin pass cooler. thats crazy!
jamies done the bollocks their mate if he got that power with out detonating, and i bet is goes too.
Old 22-05-2007, 12:43 AM
  #43
NEWTON
NEWTON's Avatar
22psi on front mount cooler,gos well but runs out on top end,i want 300+ bhp
Old 22-05-2007, 12:52 AM
  #44
series_one_rst
there only one thing for you to do if you want 300 bhp out of it. sit down and have a chat with jamie and ask him exactly what you`ll need and how much its gonna cost.
Old 22-05-2007, 12:54 AM
  #45
NEWTON
NEWTON's Avatar
im going to phone him very soon
Old 22-05-2007, 06:29 AM
  #46
Badman38
Badman38's Avatar
the spec is good its just the turbo letting you down, check the cam not worn cvh37 is an excellent profile, but the blanks kent use are shite and i would not be Surprised to see the cam worn after only a few miles...
my cvh 37 was dead to the point the car was missing after 76 miles..
newman all the way
if the cam ok just you want 300+ bhp change the turbo and run loads of boost.. a tubular would help but not really needed.. for a sub 300bhp
Old 22-05-2007, 01:58 PM
  #47
G2RSR
Bodybuilding
G2RSR's Avatar
Location: Cannot be identified by the information given.
i thought jamsport got 260 bhp with just a ported head piper 285t2 cam and 18 psi
Old 22-05-2007, 05:25 PM
  #48
NEWTON
NEWTON's Avatar
newman all the way
its funny you should say that cos after 300 miles or so run in miles one of the followers holed and it was misfiring like a twat
Old 22-05-2007, 05:54 PM
  #49
matt p
matt p's Avatar
Dont forget a garret gt25/30 turbo, gotech, front mount if your thinking of
PF Nicks car mate?
Newton you really need to get on the blower mate as it will be loads
easier
Old 25-05-2007, 11:35 AM
  #50
stuart collins
stuart collins's Avatar
WHAT!! bit higher!! surely not. to run over 15 psi on standard comp you should have water injection to help with detonating. that cant be right, do you know the comp ratio?
really mine is well over standard comp and ive run 2.2 bar with no water injection
MarK4
24-09-2008 03:39 PM
S2_RST_DK
09-06-2008 08:15 AM
Joe1199
20-05-2008 05:54 PM
c.fogarty
19-05-2008 04:48 PM
Joe1199
25-04-2008 08:15 PM
Quick Reply: MAPPERS.......(GOTECH)
