Black Top Zetec Eng into a mk 4?
I know Andy -R has done this anyone else? Any one got pics of Andys engine pulley set up?
If any one else has got one - How have you done the water pump pulley set up and what alternator did you use?
And lets see pics of the set up please
Faye ,im doing a n/a blacktop into a mk3 justnow.
Used the powersteering pump bracket and had my mate weld a tensioner on to it so it spins the belt the right way, cheap and should work fine.
Got a sierra 1.8 alternator that was on my old zvh turbo engine, made a bracket that drops it about 15mm and spaces it away from the block by 10mm. Still a bit tight with the waterpump but there is clearance.
i got one in my mk3 and i used cvh altinator bracket and altinator with different pully and the original focus belt tensioner so it tightens the belt its self! works like it was fitted factory
Did the Alternator bracket clear the water pump ok?
When you say the original focus belt tensioner ? Do you mean the power steering bracket set up to run the pulley? Have you got pics please? Im not worried about a tensioner to tighten the belt
Just need to get the water pump to run in the correct direction
Retro ford can't help as the mod they do would get in the way of the engine mount
![Cry](https://passionford.com/forum/images/smilies/icon_cry.gif)
Originally Posted by JimmyBoy
So what are the main problems installing a blacktop into a ERST compared to fitting the silvertop ?
Thanks.
Thanks.
TrevCos
Modellers Corner.
24-08-2015 09:31 PM
