Cossie M.I.S inlet manifold
#84
Originally Posted by martin-reyland
Originally Posted by GARETH T
do YOU really think its going to make a difference?
but aint you both after different things?
#85
Originally Posted by Turbosystems
Originally Posted by Doug Stirling
Same one as me
#87
For ULTIMATE power and nothng else a massive single throttle is prefered i think but as i said earlier, the individual throttles effect alot more than just throttle response.
Anyone ever seen how well a car revs on them
#88
#89
#90
I think it would. It takes a lot of skill to make a multi barrel inlet. Why bother when you get the same figures on a much simpler cheaper design.
#92
Lol, yea but it doesn't always work like that. A lot of people build their engines up over time. Then it may come apparant that the inlet is holding them back, so they put on an affordable one which will do the job very well. Customers like power figures, and the single inlet is going to give it to them.
#93
i can see what your saying, but the people who are buying this inlet are not building there engines over a long period, they are having it done by a pro here and now as the cost is huge for it, and not for compeomise ( or so they think ) so is it one large , or four relativley large
if i thought that i would gain from ITB's then i would do it, but i dont, i dont need to pay somebody to do it i could do it myself, and the parts cost is not that great on the grand scheme of things.
only proving will tell !!
#95
Caraholic
I think you will find that a lot of the Skyline tuners shy away from the ITB due to the fact that it needs an ECU capable of doing multiple maps, as it has to have a COMPLETELY different fuel and ignition map for every 10° of throttle opening - something only the top flight ECUs can do. Hence the ITBs of the Skyline's are scrapped (and also because I don't think they know how to map them with these on either).
#96
Caraholic
Anyone ever seen how well a car revs on them![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Martin's would rev to 9k if he wasn't too scared (and currently revs to 8500), as does mine, so where did you get that info from
#97
DEYTUKURJERBS
ROFL@Revs faster with ITBs on it
What relevance has that got to do with it
Not unless the single TB was a massive restiction.
Its like that on a n/a engine with a shit inlet manifold, but turbos are a bit different
The reason they go to single throttle on skylines is NOTHING to do with mapping mike, all the ECUs can handle it, even the most basic ones.
Hardly any run a big single throttle unless going for MEGA power.
The 6x TBs are good for mega power anyhow, and bigger ones are available for em too.
Reason people often bin them off is its a shitload of complexity, esp with regard to the idle valves etc etc, esp when at that level the extra response from having the throttles closer to the inlet valves isnt really noticable.
#99
It is noticable if mapped properly ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
or from 4000 rpm, loaded up engine?
#101
Caraholic
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
#103
next people wil be saying single point injection is better than multipoint.
Personaly I think these should be fly by wire and vary the inlet throat size relative to engine speed and boost
#113
Originally Posted by T S M
Gareth if the test results are good are you going to get an M.I.S to go with your Pectel T6 or is your T6 wasted on your spec ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
#114
Guest
Posts: n/a
if theres a difference,,,, its void
simple ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
#115
I have seen turbo'd 16v engines TRANSFORMED with the use of individual throttles.
The way the engine revs and how it makes its power.
Is this thread not discussing the advantages of ITBs?
#116
Mike/Gareth
Mike - i am looking forward to the test very much
I take it the MIS has fat runners? Have your ports been enlarged, or does the MIS taper to match them. How do the ports vary from the old engine?
However, Gareth is right - the test is void
I realise you probably have little interst in putting it on a single body - just to see - but that would be the only true way.
With regars to the map needing to be changed every 10degrees - i have been a strong advocate of this for a long time - not the 10 degrees bit, but the fact that the throttle effectively changes the VE of the engine.
Rick.
Rick.
#117
Caraholic
Rick,
Obviously you didn't both looking at my post in the resto section, as mine is NOT an MIS manifold. The MIS manifold runs a single TB. Martin has basically bastardised his MIS manifold to have ITBs fitted
(brave man
My inlet is totally port matched, as the Mountune one (designed for 300bhp) only had 24mm ports. These have now been matched and are the exact same as the head intake ports (27.5mm). Photos of all this machining are in my resto thread
. With the ITBs open, there is a clear path straight to the valves
Si B
12-09-2015 06:49 AM
