Rear Diffs
Old Jan 7, 2007 | 08:26 PM
Ryan's Avatar
Ryan
Default Rear Diffs
Can someone please explain the pro & cons of all the types of diffs available.
only looking at a 7.5" not a 9"
So quiafe, gripper etc etc, plated, uprated vc
please dicuss the options and if some are more suited to driving styles and power levels.
Ryan
Old Jan 7, 2007 | 08:44 PM
The DIVA's Avatar
The DIVA
Ryan.......
I looked at and tried them all before settling on a Quaife ATB...
The V.C is very good as std(They used a V.C in the 9" as well with no problems)but most of them are sloppy now so a rebuilt uprated one is a must...
The gripper plated diff is very good but is quite noisy in operation and being plated will wear and need regular rebuilds depending on how much/hard you use it...
The ATB i found to be excellent,it drives very hard out of bends etc without wanting to go sideways all the time and is quiet and maintenance free....The only problem with ATB diffs is if your car has a tendency to lift a wheel they will loose drive as they obviously lose grip to the wheel they are biasing the torque against,as my car is very taught it is not a problem for me.....
My car will be ready fairly soon so if you want to have a blast to see what they are like,give me a shout mate....
Old Jan 7, 2007 | 09:30 PM
Butch.'s Avatar
Butch.
excellent advice there mr diva
Old Jan 7, 2007 | 09:37 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Originally Posted by The Diva
Ryan.......
By my reckoning Ryans will be ready before yours
Old Jan 7, 2007 | 09:44 PM
The DIVA's Avatar
The DIVA
Ryan.......
I think even i`m safe there Rich......
Ryans spec will change another 25 times before he starts to put it back together...
Old Jan 7, 2007 | 10:06 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Ryan.......
Only 25
Old Jan 8, 2007 | 11:39 AM
Ryan's Avatar
Ryan
ohhh the pain.
engine is finalised so no need to go any further, not that i can go much further with it, unless i change the crank
suspension and brakes are finished.
wheels are finished.
shell is finished.
cooler/rad and engine bay parts all sorted.
its just a case of bolting it together
Old Jan 8, 2007 | 11:44 AM
xr2i-carl's Avatar
xr2i-carl
gotta love 'the diva'
Old Jan 8, 2007 | 11:53 AM
bud-weis's Avatar
bud-weis
Football Cwazy
i have a Quaife ATB.....plus point is they are pretty bullet proof,downside for me is sometimes you can feel it working when you don't necessarily want it to (makes the rear end 'steer' ever so slightly)
obviously any of them are better than standard though!! you can also try mine any time you like
oh and i need another loom sometime soon
Old Jan 8, 2007 | 11:55 AM
GARETH T's Avatar
GARETH T
if your going to use the car on the road alot,, just get your standard diff rebuilt and pumped up
Old Jan 8, 2007 | 11:57 AM
S2martin's Avatar
S2martin
Ex Full Price gold member
Off topic Ryan, but send me another text as i went to ring you and i deleted the text with your number instead of saving it
Old Jan 8, 2007 | 08:25 PM
Ryan's Avatar
Ryan
standard diff to take 550 hp?
martin
07919537128
Old Jan 8, 2007 | 08:27 PM
rapidcossie's Avatar
rapidcossie
martin
07919537128
mines does
Old Jan 8, 2007 | 08:48 PM
Ryan's Avatar
Ryan
what parts did you uprate euan??
and by whom.
and finally...
what cost
Old Jan 8, 2007 | 08:49 PM
Kevin Sharp's Avatar
Kevin Sharp
martin
07919537128
why mess around with 7.5" diffs then .....fit a 9" fit and forget will be cheaper in the longrun..not to mention a lot less greif
Old Jan 8, 2007 | 08:54 PM
Ryan's Avatar
Ryan
because 7.5" can handle it no problems, if there uprated properly.
and 9" is way too much money and also finding the right ratio.
Old Jan 8, 2007 | 08:59 PM
abdr500's Avatar
abdr500
i have a Quaife ATB.....in my 2wd cossy and its money well spent
Old Jan 8, 2007 | 09:06 PM
Kevin Sharp
fairenough if thats what you want to do then ryan...wasnt trying to be funny but if you buy a 9 incher it will always be worth good money if you ever want to move it on
wonder why ford didnt use a 7.5" in the touring cars then
Old Jan 8, 2007 | 09:07 PM
rapidcossie
and by whom.
and finally...
what cost
None
by ford
150 exchange
Old Jan 8, 2007 | 09:08 PM
rapidcossie
do you have any spare 9" dif for sale kev?
Old Jan 8, 2007 | 09:10 PM
Kevin Sharp
no sorry the one out of my escort i broke up is fitted to my 3door
Old Jan 8, 2007 | 09:46 PM
JonnyBravo's Avatar
JonnyBravo
Euan, besides doing 180+ you must be very gentle on your transmission ? that or your one lucky bloke !
After seeing what a 550bhp saff done to a well specced 7.5" diff twice I'd go with a 9" if money allowed.
Ofcourse like most others on here though I'd probably risk using something a little cheaper and lay off the heavy abuse.
Old Jan 8, 2007 | 09:50 PM
rapidcossie
i would say i am pretty easy on it...
never use full throttle in first or second(not that it would grip anyway)
i have had two diff now both while the engine was running 400+ ATW.
both noisy but working fine.
have done 10k miles...
with a car better set up than mine (traction wise) i have no doubt that a standard set up wouldnt last long.
saves spending 2k on a box and another 1500 quid on a diff tho
Old Jan 8, 2007 | 09:51 PM
rapidcossie
take it the three door is getting finished then?
Old Jan 8, 2007 | 09:53 PM
Kevin Sharp
its only needing a day or so spent on it doing some minor wiring and plumbing jobs....so yes probably...when i can be bothered
Old Jan 8, 2007 | 09:54 PM
NEIL A's Avatar
NEIL A
will be tax exempt time its back on the road
rapidcossie
maybe thats the idea?
Old Jan 8, 2007 | 09:55 PM
NEIL A's Avatar
NEIL A
well you know what they say about us fifers
Old Jan 8, 2007 | 09:56 PM
GARETH T's Avatar
GARETH T
anything to save a penny
Old Jan 8, 2007 | 10:02 PM
marco polo's Avatar
marco polo
i'm sick to death typing about fooking diffs
drag up an old post of mine
i must have replyed on about 20 different topics by different peeps about bloody diffs
you know what to do ryan
Kevin Sharp
actually thats a good idea neil its eta for being back on road is 1/8/2011
Old Jan 8, 2007 | 10:03 PM
Kevin Sharp
me too...fit a 9 incher..job done
Old Jan 8, 2007 | 10:07 PM
marco polo's Avatar
marco polo
i can get any 9" diff anyspec vc/pated expensive tho
i am saving up for a 9" xtrac plated diff and going to part ex my gripper 7.5 diff
marco
Old Jan 8, 2007 | 10:10 PM
bud-weis's Avatar
bud-weis
Football Cwazy
marco
how expensive??? i'll swap my ATB and a packet of midget gems for one
Old Jan 8, 2007 | 10:13 PM
marco polo's Avatar
marco polo
they are over 3k for 9" xtrac plated diff but thats with any CWP all brand new of course
the vc one is cheaper but the vc can be uprated to 900Nm if needed
marco
Old Jan 8, 2007 | 10:17 PM
marco polo's Avatar
marco polo
all the casing are brand new using the original 909 moulds (Ricardo who made them for Ford )that were built for Ford motor company
marco
Old Jan 8, 2007 | 10:34 PM
Kevin Sharp
thats a good price for a brand new unit marco
Old Jan 8, 2007 | 10:50 PM
marco polo's Avatar
marco polo
kev
the whole diffs are brand new
CWP's /bearings /Vc units /plated units /casings /side bearing cases/
cwp's from 3.62 /3.9 ,4.1,4.4,4.6,4.8,5.1 the whole lot
marco
Old Jan 8, 2007 | 11:11 PM
marco polo's Avatar
marco polo
[quote="The Diva"]The gripper plated diff is very good but is quite noisy in operation and being plated will wear and need regular rebuilds depending on how much/hard you use it..[quote]
yes that is depending on how the plates are set and the ramp angles
we normaly have them set progressive so one wheel spins quicker than the other when cornering thats what we call "road use"
they are noisey when they are set for "race" use they grind a bit when cornering
when you have them new and they are set for road use they are noisy at first untill the plates bed in and when it's bed in they are quite and you wouldn't know that you had a modded diff in there
i had my diff redone and it was noisy at first but now it's quite even when it's hot so i'm a happy man
marco
Old Jan 8, 2007 | 11:15 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
ouch 3k lol , but I suppose by the time you have fucked about changing millions of std diffs then its money well spent..... What sort of launching abuse can the 9" diffs take? What rear beam mods have to be done?
I'm still thinking Jag 10.5" diff.......... just a shame about the weight... wonder how much an alloy casing for one would be?
