tappets? stalling? help?
Old Jan 2, 2007 | 05:17 PM
rst in breaking's Avatar
rst in breaking
Default tappets? stalling? help?
hey, i was drivin my 2.0 fiesta si today when the sump bolt came out!!! which i was un aware of as i was driving. when i came up to a roundabout and pushed the clutch down it stalled (i didnt realise the oil till a minute later when i was parking) could this be ive lost the oil so the tappets have built up air in them as it no longer runs on tickover? but is fine when i rev it?? its louder now when i rev it (not realli loud though) any help much appreciated, cheers guys
Old Jan 2, 2007 | 05:23 PM
so u lost all the oil and the warning light never came on
Old Jan 2, 2007 | 05:26 PM
PeterLucas's Avatar
PeterLucas
bottom end prob fooked
Old Jan 2, 2007 | 05:34 PM
rst in breaking
bottom end aint knocking or anything, was at really low revs (i know it can still happen) but i think i turned it off before i lopst all the oil. so could my problem be the tappets?
Old Jan 2, 2007 | 05:39 PM
Alvyn's Avatar
Alvyn
IF and I mean IF you've been lucky and the engine's still running the followers are noisey due to lack of oil in them/engine so go get some a bit sharpish!
ps how did the sump plug drop out been upsetting anybody?
Old Jan 2, 2007 | 05:44 PM
PeterLucas's Avatar
PeterLucas
Assuming you are now testing with a tight sump plug and some oil. If it was air in the lifters they would shut up as soon as they got hot...
If you ran the car for anything over a min with no oil / oil pressure you are lucky its running!
Old Jan 2, 2007 | 06:24 PM
rst in breaking
ain upset no one lol, never checked it after the conversion, my friend drained the oil and i can only gues the bolt was put in hand tight, i swapped the sump onto the 2.0 and never checked it so my fault . i was testing it with oil but i cant keep it ticking over unless i rev it up?
Skinz's Avatar
Skinz
Default Re: tappets? stalling? help?
Absolutely, definitely needs a new bottom end, or if you're handy with the spanners, a full rebuild. Ouch. Not a nice start to the new year.
Old Jan 2, 2007 | 06:27 PM
rst in breaking
theres no noise from the bottom end and isnt smoking as if there is, i went to do a compression test but my tester was only short reach thread sowouldnt work, soi need to get hold of one of these?
Old Jan 2, 2007 | 06:33 PM
gup's Avatar
gup
best thing to do mate is rip the plugs out turn over by hand so its defo not catching the valves on the pistons disconnect the coil pack and turn the engine over as this will pump oil up into the lifters try this first fella also the plug for the i.c.v hasnt come off has it
Old Jan 2, 2007 | 06:47 PM
rst in breaking
cheers fella, i was thinking ive read before away of helping pump them up before, il check iscv, cheers mate
Old Jan 2, 2007 | 06:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Look at it this way - If you saw the oil light come on, then its fucked
Old Jan 2, 2007 | 06:52 PM
Old Jan 2, 2007 | 06:53 PM
rst in breaking
oil light never came on luckily, providing it works, it starts up though, got a feeling its something stupid
Old Jan 2, 2007 | 06:56 PM
rst in breaking
Old Jan 2, 2007 | 07:13 PM
Alvyn's Avatar
Alvyn
[quote="Graceland"]Look at it this way - If you saw the oil light come on, then its fucked
NOT necessarily I know a few Ford models that when low on oil and while cornering a bit fast the oil light WILL come on!
it more than likely wont tick over because the valves are not working properly! try and keep the revs up to about 3 thousand for about 5-10 mins to let the oil get round and into the lifters!
Old Jan 2, 2007 | 08:51 PM
Tor @ Racefix Motorsport's Avatar
If the engine has been out of the car, are u sure the oil pressure lead was put back on to the switch? If not its no wonder it never came on......
Old Jan 2, 2007 | 09:11 PM
XRT_si's Avatar
XRT_si
You sound pretty certain!
Paul you do have some bad luck dont you? If its not ratteling or smoking sounds like you got away with it
What does it go like by the way?
Old Jan 2, 2007 | 09:21 PM
rst in breaking
problem sorted, bit more petrol andcable had slidon the throttle body a bit causing it to close on tick over, damn im lucky, just need to sort the miss fire now lol, cheers guys
Old Jan 2, 2007 | 09:29 PM
PeterLucas's Avatar
PeterLucas
Wish I was that bloody lucky!
You cant have lost all the oil then surely?
Either way your in luck
Old Jan 2, 2007 | 09:35 PM
rst in breaking
imust have turned it off just in time. sum1 loves me up above lol
davidfordrs
Sep 21, 2015 04:23 AM
jay030787
Sep 18, 2015 04:38 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Roosie
Aug 13, 2015 07:40 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
