ecu and map sensor question on cossie?? HELP
Obviously, ECU board can (and have been in the past) be swapped into other cases, but a rough guide is:
L1 - small yellow CO pot
L6 - larger, white CO pot
L8 - as L6 but minus mounting lugs
P8 - as L8 but no CO pot (except a few very early ones which did have a CO pot)
The MAP sensor will have a code on it, don't go by the colour of the moulding as not all 3 bar MAP sensors are grey.....
Post up any ECU sticker codes, and the MAP sesnor part no.
kosienutter
31
22-08-2015 09:55 AM
