Problems with new Cossie......HELP
Old Oct 21, 2006 | 06:39 PM
Default Problems with new Cossie......HELP
...changed the lifters to day and found on the front 2 allen key bolts that hold the first cap on with the oil seal (camshafts) came out with helicoils on them...then noted some cam caps just spun and couldnt put up to ft/lb....they just span..so wound the studs out to find helicoils coming out too ...OBVIOUSLY in the past the nuts and allen key bolts where not torqued down and just put on over tight causing the need for the helicoils ...the 13mm nuts are 20ft/lb and the front bolts are 10ft/lb MAX...hardly anything...
So what can i do i NEED to get it running for Monday..is rehelicoiling ok..and where can i get a kit from???...need about 4 studs to go back in and 1 allen bolt.
ANYONE HELP??????
Old Oct 21, 2006 | 06:57 PM
Basky's Avatar
Basky
could get you the helicoils phil but it wont be until monday
but i would of thought it to be ok to recoil them if the threads are ok
Old Oct 21, 2006 | 07:12 PM
dave cos4x4's Avatar
dave cos4x4
should be abe to re-helicoil them.
Stop fooking messing with it,you've broken it now.
Old Oct 21, 2006 | 07:25 PM
..where can i can helicoil kit TOMMORROW in the Kent area??????
Old Oct 21, 2006 | 07:29 PM
L33 BYT's Avatar
L33 BYT
Most proper hardware stores should do them.
Some of the better autofactors may do them to.
Old Oct 21, 2006 | 07:30 PM
jon@work's Avatar
jon@work
Be careful Phil when you do put it back together - shouldn't those torque figures be Nm, not lbft - ie 10 and 20lbft are too tight ? (Ihaven't got my manual in front of me so would be worth checking)
Old Oct 21, 2006 | 07:32 PM
Jon no thats the converted value from NM
...would B&Q do this kit?
Old Oct 21, 2006 | 07:39 PM
jon@work's Avatar
jon@work
I doubt B+Q will do them
your problem is is that the helicoil kits are about Ł20-25 each - 2 sizes are required, so it's gonna be expensive unless you can find someone with the appropriate sizes that you can borrow the kits off (like me but I'm in Nottingham)
Old Oct 21, 2006 | 07:45 PM
...halfords????
...ANYONE in kent?
Old Oct 21, 2006 | 07:50 PM
Eagle's Avatar
Eagle
Super Moderator
why can you not re-use the helicoils that came out????
Old Oct 21, 2006 | 07:52 PM
...they broke up!
Old Oct 21, 2006 | 08:03 PM
Ex-Finesse's Avatar
Ex-Finesse
Asked my Dad if we have any of these at his business, as it's mechanical & vehicle based, plus we're in Kent.
Unfortunately don't have any, sorry.
How about a garage? They may have some in stock if this happens to them?
Old Oct 21, 2006 | 08:05 PM
Eagle's Avatar
Eagle
Super Moderator
...they broke up!
bugger
Old Oct 21, 2006 | 08:11 PM
Rolls's Avatar
Rolls
Its very unlikely halfrauds do them mate.... - unless they've changed a lot since i left a year and a half ago.... - may be worth giving the biggest store near you a call though...
Old Oct 21, 2006 | 08:39 PM
...anywhere else?
Old Oct 21, 2006 | 08:41 PM
Rolls's Avatar
Rolls
would machine mart do them?- may be open?
Old Oct 21, 2006 | 08:59 PM
DazC's Avatar
DazC
If they broke up, it's very unlikely that what came out was a helicoil as it would have been steel and quite hard.
It's more than likely the remains of the aluminium thread from the head.
I doubt you will find somewhere tomorrow to be honest Phil. Try Machine Mart and the usual Halfords and other accessory shops. You may get lucky.
Old Oct 21, 2006 | 09:20 PM
Alvyn's Avatar
Alvyn
got mine from Machine Mart abit a yr or so ago!
Old Oct 21, 2006 | 09:23 PM
GARETH T's Avatar
GARETH T
i agree
Old Oct 21, 2006 | 09:35 PM
Andreas's Avatar
Andreas
Had mine helicoiled and it lasted a few months.
Replaced it with bigger bolts and its been fine for seven years.
Old Oct 21, 2006 | 09:46 PM
GARETH T's Avatar
GARETH T
helicoils if fitted right should last a lifetime
they dont like being wound in and out though
Old Oct 21, 2006 | 09:50 PM
Franco's Avatar
Franco
You must have a motorfactors near you Phil, they'll do!
Ps had to helicoil min today
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
