Cossie brakes on Fiesta.
How easy is it to put some front Cossie brakes (any which will fit under 15s) on a Fiesta Mk5? Do they go for big money or are they quite a cheap upgrade? what size discs are they? and is it a case of just bolting them up?
Cheers.
Cheers.
Baby Cheesus
i used 4x4 stuff on the mk6
had to space the callipers about 6mm - this was done with 3 10mm washers on each bolt. does the trick lol
im not sure of the offset of 2wd discs but that may be why peeps suggest that, as then you wont need the spacers for the callipers but dont hold me to that.
with regard tot he braided lines, i used esc cossie ones, and i know that with the mk5 escorts the solid brake line has a male fitting into a female end on the rubber hose that goes to the calliper, but on the mk6 they are both male ends so i needed a male to male joiner and cant remember who i got em off on here but any nmotor factors should sell then if needed
HTH Danny
HTH Danny
Thanks for the replies so far!
The reason I ask is I'm going back down to 15s, now I don't know if it's worth just purchasing some Mondy V6 brakes, which are 280s and go on pretty easily.
Or I could swap a mate for some ST150 brakes, which are also 280 and should go on straight away.
Do the cossie calipers make *that* much of a difference?
Baby Cheesus
yes lol
the piston is fucking huge compared to the std piss small one
also the increase in disc size is the main benfit
remember my mk6 i got off deano, well witht he hispec spacers and 280mm discs, the brakes were pretty good, but fuck me, when i changed to cossie 4x4 stuff the difference was huge even tho it still had a 280mm disc
Ah, I best get trying to source some of these calipers then I think..
As long as they'll fit under the wheels I shuld be fine!
Cheers Dan,
Cheers Dan,
what about 2wd calipers which a re 4 pots? don't they have a better braking power? over single piston 4x4 calipers then peeps?
only reason i ask is, i'm doing the cossie front brake conversion on my s1 with standard wheels and i'm using 4x4 calipers and 2wd discs. But i figured surely the 2wd calipers which have 4 pistons would make the braking alot more better, by spreading the braking effort across the pads, rather than 1 piston just pushing in the middle of the pad as on the 4x4 cosworths?
cheers
cheers
I used 4x4 calipers and 4x4 discs on mine. Carriers were spaced by 4mm. Fitted under standard 15" z-s rims without any problems. Awesome setup for the money, think I paid 150 quid all in.
You see, I've got 300mm brakes on there already, from the ST170.
Problem is, they're not going to fit under my 15s, so I need some decent stopping power that'll fit under them..
So I'm looking for some 4x4 calipers, and 2wd discs? and that's all I should need?
Cake lover!
Just a thought if not already sorted rims.
Definatly Nash, the caliper needs shaving down, and tbh, I don't really wanna risk messing with that.
Also, you have the arse ache of the brakes cooling down.
Sure about the Teg having FRS brakes? FRS use's 325-330mm discs IIRC?
Cake lover!
I mean new shape tegs[dc5 not dc2 like mine] import only use brembo calipers aswell. I know they just managed to get 15" on them but was a tight fit. Just a thought anyway, you should be able to sell ST170 brakes and still have cash left over after getting cossie ones though.
Cheers nash.
Just tried the 15s on the front brakes, NOPE, not happening.
I could probably shave away a bit of the caliper but is it really safe to do this?
TPM961
15-01-2018 10:50 AM
Andypandy260
23-09-2015 10:28 PM
