Boost, pistons, fuel...
Old 15-10-2006, 02:25 PM
SapphyMike
SapphyMike's Avatar
Default Boost, pistons, fuel...
If a set of pistons are prone to melting at 14psi of boost on a T25 with a crappy interwarmer, would they still melt at 14psi with lower intake temps??
or say running less boost on a larger turbo with lower intake temps?
Old 15-10-2006, 02:38 PM
Rick
Rick's Avatar
not going to make much difference tbh. The flaw is obv in the piston.
Old 15-10-2006, 02:41 PM
dave cos4x4
dave cos4x4's Avatar
not right if they are melting,not set up right is it.
Old 15-10-2006, 02:59 PM
SapphyMike
SapphyMike's Avatar
Dave,
Rover pistons are weak apparently, and will melt at 14psi hence the intake lower temp question
Old 15-10-2006, 03:03 PM
dave cos4x4
that bad are they.
Old 15-10-2006, 03:06 PM
SapphyMike
SapphyMike's Avatar
seem to be
not to mention the pg1 gearbox
230bhp would be nice LOL
Old 15-10-2006, 05:14 PM
Rick
Rick's Avatar
higher inlet temps lead to increased possibility of det, and less power due to less density.
It seems like your pistons can only take so much cylinder pressure, ie power. You can jiggle about how you make this power, but in the end you'll still be left with the same cylinder pressure's, or more correctly, work done on the piston.
Old 15-10-2006, 05:40 PM
xr4x4rs
xr4x4rs's Avatar
your problem is the mangememnt lol
it can only fuel enough for 14psi max dangerously aswell, safer at 12psi
my mates went through this kept cracking number 3 piston even on fresh engine rebuilds etc
final engine build he had omex fitted and was the best mod ever to get rid of the crappy rover ecu
dont bother with these piggy back things either as its cheating death of teh engine, think it only lets you run more boost but doesnt give you fuel, as there is no adjustment for fuel anywhere on them
change teh mangement
Old 15-10-2006, 09:13 PM
SapphyMike
SapphyMike's Avatar
hmmmm, so with a decent management and larger turbo, running say 18psi would be ok? (larger cooler too)
Old 16-10-2006, 09:34 AM
AlexF
AlexF's Avatar
melting is temptreture...
so lowering detonation causing factors (like crap fuel, high charge temps) will help.
Backing out a little timing would help too.
If they crack then you have found the limit of the pistons - anything else is more a setup issue.
Alex
Old 16-10-2006, 12:32 PM
xr4x4rs
xr4x4rs's Avatar
problem is the t16 engine has no adjustment, fixed fuel, fixed timing
not even an adjustment for co as its all ecu controlled
honestly change the management to something that can be adjusted and you wont go wrong
plus you can also go coilpack aswell if you havnt already got it
but its fairly easy to build a low comp engine aswell using rover parts if you can find them
Old 16-10-2006, 02:48 PM
scruffythefirst
scruffythefirst's Avatar
Don't emerald ecu's plug straight into rover looms?
Old 16-10-2006, 02:51 PM
xr4x4rs
xr4x4rs's Avatar
yes they do mate
Old 16-10-2006, 08:42 PM
SapphyMike
SapphyMike's Avatar
Emerald looks promising!
Old 16-10-2006, 09:00 PM
James
James's Avatar
Could you wire a 5th injector setup?
Old 16-10-2006, 11:45 PM
xr4x4rs
xr4x4rs's Avatar
not worth it mate honestly
my mate had bigger intercooler water injection everything bar mangement and still blew up to lack of fuel at 14psi
rover ecu are shit
but change them and there a totally different car
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Boost, pistons, fuel...
