Need a little help!
Old 16-10-2006, 10:25 PM
Magnex20011
Magnex20011's Avatar
Default Need a little help!
Hi Guys.
I have an Escort Series 2.
The car starts fine but after a couple of minutes idling the exhaust smokes badly.
The car is chucking out loads white smoke (not blue).
Has the car been serviced with the incorrect oil ? is this causing the oil to be burned to quickly ?
What oil should the car be serviced with ?
Any advice is greatly appreciated!
Thanks Guys
Pete
Old 16-10-2006, 10:37 PM
Physio
Physio's Avatar
White smoke's usually a sign of head gasket failure.
Old 16-10-2006, 10:43 PM
The Youth.
The Youth.'s Avatar
could also be a shagged turbo, check for play (in/out) on the shaft
steve
Old 16-10-2006, 10:46 PM
david
david's Avatar
Your sig says 1.8 turbo esc , what engine is it mate ?
The replies above are the first 2 to check though
Old 16-10-2006, 10:49 PM
Magnex20011
Default 1.8
Hi Dave.
Its been converted to an 1800. I have nooo idea how I can prove this , but i have the receipts.
The turbo is also a turbo technics job.
The car pulls like a train and the sound from the turbo far louder than standard.
Fuck*** smoke tho is pissing me off. I have a feeling its a low grade oil in the engine , or am i talking bollox lol
Pete
Old 16-10-2006, 10:56 PM
david
david's Avatar
Not doubting the conversion at all mate
how has it been built though, do you know ? have receipts for skimming the pistons or different pistons ?
is it a CVH or zetec bottom end ?
Old 16-10-2006, 11:04 PM
Magnex20011
Default Zetec
Dave
Sorry mate, I meant prove it to myself !
How can I tell if the engine really has been bored ?
The car apparently has a Zetec bottom end.
I have a receipt from an engineering company (cant rem the name). That shows the rebuild is a 1.8 costing £1900
Also do you think I should go back to standard ? I think of swooping my car for a standard white RST same age.
My car has Tarox brakes, FSH, suspension , samcos, uprated turbo (4 k of recipts), respray
Would I be conned if I swoped it for a standard car in slightly better condition ?
I have been offerd 2300 for my car , this is also tempting!
Pete
Old 16-10-2006, 11:14 PM
david
david's Avatar
Default Re: Zetec
Originally Posted by Magnex20011
Dave
Pete
Cant tell if its been bored without taking the head off mate.
If its a zetec bottom end then the dipstick should be situated at the front left hand corner of the engine. Ideally the pistons should have been replaced for proper ones or skimmed at least . you can run totally std 1.8 zetec bottom end but you are limited as to what they will do and how long it will last. I have one of these in my FWD car but i know what it is and if it goes then it goes and im only £50 out of pocket.
Wether you should go back to a std bottom end and how much your car is worth is bugger all to do with me mate. all I can reccomend is to get your car along to the nearest reputable company and have it properly checked over.
tell us where your from and im sure someone will know a good place near you
Old 16-10-2006, 11:54 PM
xr4x4rs
xr4x4rs's Avatar
if teh smoke was oil the it would be blue
if black its fuel
if its white its water
as its coming out of the exhaust then its either turbo failure or head gasket
does it get hot,lose water, miss fire anytime?
if the turbo is watercooled block the water pipes both ends of the turbo, if its stops then the turbo is knackered, if it doesnt then head gasket
only tests you can do i think, bar a compression test aswell
