transit problem
Old Sep 27, 2006 | 03:03 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default transit problem
heater has packed up, was working fine got in this morning and nothing, checked fuse but its ok, any ideas its on an n plate if this helps, cheers
Old Sep 27, 2006 | 03:26 PM
RS500/364's Avatar
RS500/364
my saff had a problem like this jumped it with a 12v and worked again !!
Old Sep 27, 2006 | 03:34 PM
se mk3 cabbie
strange
Old Sep 27, 2006 | 06:44 PM
DazC's Avatar
DazC
They usually burn out the switch or the heater resistor next to the drivers headlamp (a thing with loads of coil windings in it).
If it's the resistor it will only work on speed 3. If it's the switch, it won't work at all.
Old Sep 27, 2006 | 07:02 PM
DangerousBryan's Avatar
DangerousBryan
sometimes melt the fusebox where the heater fuse go's in as well. try jiggling the fuse about or reach up the back of the dash and jiggle the multiplug on the back of the switch.
bryan
Old Sep 27, 2006 | 07:39 PM
Alvyn's Avatar
Alvyn
DazC how much is a replacment resistor? as mine does that and have never bothered to change it in 3 yrs
Old Sep 27, 2006 | 07:44 PM
DazC's Avatar
DazC
Not much mate. There is next to nothing to them. Just ring Ford and ask fr a Transit heater resistor and thell thenm the age of your van.
You will probably find the plug has corroded so you will have to cut the plug off and replace them with spade terminals. Make sure you get it right otherwise you;ll have the fan speeds all mixed up and the wiring for the slower speeds can't take the current for the higher speeds for a long time.
Old Sep 27, 2006 | 07:49 PM
Alvyn's Avatar
Alvyn
DazC thanks
Old Sep 27, 2006 | 08:01 PM
Chris Honeywell's Avatar
Chris Honeywell
M8 i got an N plate transit and theses things can go for a pastime
I'm sure there no more than Ł15 they reduce the voltage i think so you get the 3 speeds on the blower
thats why normally when they go the fastest speed is fine as im sure thats the full 12 v
Old Sep 27, 2006 | 08:07 PM
DazC's Avatar
DazC
Yes they can fail quite often sometimes. It just depends on wether you can put up with the blower on full speed all the time when you need it or not.
Old Sep 27, 2006 | 08:09 PM
se mk3 cabbie
thanks for info will check said things tomorrow
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
