Got a Pectel Monitor?...
Old 22-09-2006, 11:35 PM
Rippers
Monte Geek
Rippers's Avatar
Default Got a Pectel Monitor?...
Where did you mount it pics please
Seen Mike R's
and Damo's (Damo is your screen blue?)
I was thinking of putting it either in the blank above the radio (bit boring)
Or getting a custom mount in the electric sunroof motor cover like Dave had with his Defi monitor (can't find a pic)
Any other suggestions?
Old 22-09-2006, 11:42 PM
richard_syko
richard_syko's Avatar
Steering wheel
Old 23-09-2006, 04:07 AM
Kelv
Almost there!
Kelv's Avatar
Id have said in the Banana pod as mine was - and Mike's obviously, but i know you like your standard gauges there!!
Old 23-09-2006, 05:47 AM
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
Old 23-09-2006, 08:48 AM
GARETH T
GARETH T's Avatar
Old 23-09-2006, 08:55 AM
TurboGuido
TurboGuido's Avatar
Old 23-09-2006, 09:16 AM
Rippers
Monte Geek
Rippers's Avatar
Well after the chat I had with Rainbird last night those standard gauges maybe gone
Where did you and mike relocate your rotary dial?
Old 23-09-2006, 09:37 AM
Andreas
Andreas's Avatar
Not an escos though but I take every chance posting my pics.
Custom face plate by Nomad.
Selector...
Old 23-09-2006, 09:43 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
hsome kool mounting places.
No point showing mine as its a mk3/4 escort
Old 25-09-2006, 08:43 AM
Franco
Franco's Avatar
NOOOOOOOOOOOOOOOOOO........
Another bloody place i can't fit my SECS monitor too! stop spending money!!!
Old 25-09-2006, 09:06 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Paul,
Don't forget that it you remove the main dash, you loose the power supply and regulator for the gauges in the banana pod, so these wouldn't light up any more...
Also, IMO there is no point in mounting it out of your line of site. You want to put it where a quick glance can view it.
Old 25-09-2006, 09:45 AM
foreigneRS
Testing the future
foreigneRS's Avatar
although the peak recall function is still a useful feature if it is not in line of sight
Old 25-09-2006, 10:02 AM
Mike Rainbird
Caraholic
I think this is only available on certain versions?
Old 25-09-2006, 10:05 AM
JTECH James
Passion for Fords!
JTECH James's Avatar
you could wire the invertor up seperatly to work the banana opd lights, and fix it behind the dash.
Old 25-09-2006, 10:14 AM
Mike Rainbird
Caraholic
I would be worried that even on the lowest setting on the dimmer, it would burn the three gauges out, as the inverter is designed to power these, plus the four gauges in the dash, so would need testing first.
Old 25-09-2006, 10:17 AM
JTECH James
Passion for Fords!
yep ,but lower power invertors are available, a little homework and you should be able to work the power usage and buy one accordingly ,then mount it behind the banana pod.
your idea is best though..... throw them in the bin!
Old 25-09-2006, 09:15 PM
Damo V
Damo V's Avatar
Personally I like mine ROFL... Sits perfectly in my line of sight, though I am going to move the SECS monitor from its current position
DixieTheKid
11
06-06-2020 11:20 AM
jessie_rs
62
06-08-2019 09:27 PM
jay030787
25-09-2015 01:38 AM
Steve Cooper
15-09-2015 04:39 PM
Roscopeco
14-09-2015 05:32 PM
Quick Reply: Got a Pectel Monitor?...
