Which Inlet Manifold (Zetec Turbo)
Which is the best inlet manifold to use on my 2.0 zetec turbo??
I have a rover turbo one but would a EFI one be better??
Would a Rs 1800 one bolt striaght onto my 2.0 head??
The engine will have about 300bhp
Thanks Brian
Thanks Brian
Fucking superstar........
The rover one will flow more than the other 2 you've mentioned. The EFi one is next to useless as the ports aren't even close to being lined up.
Use the rover inlet
Use the rover inlet
Originally Posted by Pennywise
Whats the advantage of an RS1800i to an (F)RST
or is it because the rs1800 is a straight fit being from a zetec engine?
Monte Geek
The EFI needed an adapter plate to fit the Zetec head and it wasn't matched very well
The RS1800 was a tuned version of the EFI manifold and mated straight to a zetec head.
Ahmed did a lot of flow tests comparing different inlet and the RS1800 was his choice
Monte Geek
But the XR2i 16V had a zetec head and EFI manifold, I'd always thought the RS1800 was special because of the size of the throttle housing and the insides where tuned to be a better match
Originally Posted by Paul Ripley
If I had my time again I'd deffinaly used a RS1800 inlet
Think I keep a look out for one from now on.
Originally Posted by Brian
Originally Posted by bigbobby
So if i was building a zetec turbo which is what i think im gona do will a rover turbo inlet bolt straight on if so how is this?
Gaz
Gaz
Brian
Sorry for the hijack mate but how much modding?
Brian
