Cossie Injectors fitting question (update prob solved)
Monte Geek
I pulled the Greens out and fitted the X039's without paying too much attention to how they where before
But they just look wrong
My concern is that the tops of the injectors fit the rail fine but the bottoms don't go all the way into the inlet, almost as if the injectors are too short
Anyone help me on this?
Can't tell by the pics but as long as the o-rings are properly seated in the manifold you should be fine. I'll be installing a set of these sometime in the future... thanks for the heads up.
Looking a bit closer... are you using the correct slot on the injector for the clip? It should be the first slot under the o-ring.
Monte Geek
Originally Posted by SECS
Are you sure the fuel rail is flush with the manifold mountings ?
The clips are on the first notch
Does anyone have a pics I can compare to please?
when i fitted my greys they looked like that it was down to the bottom o ring being a tight fit as they were new just put a bit of good old wd on em and they slid rite in hope this helps
Paul, from you first pic it looks like the new injectors are not fully pushed in to the inlet manifold holes.........
Might sound like a daft question, but you DID remove the protective (plastic) nozle covers before fitting did'nt you?
Monte Geek
Yes that's a very daft question Franco do one
I spoke to Harvey and it sounds like the injectors where supposed come with some spacers Just sent him the pics and waiting on confirmation
Monte Geek
Harvey confirmed the spacers where missing and it sending me out a set tonight.. Top man
The injectors are Weber X039's a sort of alternative to Grey's with a different spray pattern apparently. The dyno maxed them out safely at 438bhp
Monte Geek
Problem solved
A and C are the Weber X039's and B is a Bosch green
Despite being different shapes they are the same lengths.
The red line shows you where the rubber o-ring is postioned on A compared B.
As suspected the X039's needed a spacer but after fitting one the caps where two big
So dug out the old original injectors and nicked the caps of them and as you can see by the blue line they are now identical in spacing
They now fit perfect
you say the dyno maxed them out at 438..
surley you want a slighty bigger injector that isnt maxed out as a safety margin?
read somewhere that you shouldnt really push the duty cycle of your injectors past 90%
CabrioTurbo
01-08-2015 11:04 AM
