Ahmed style fuel pump fitting kit.... MikeR maybe?
Old 01-09-2006, 11:18 AM
  #41
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Dave had no problems with his .
Old 01-09-2006, 11:26 AM
  #42
Franco
Franco's Avatar
Oh i bloody give up!!
Old 01-09-2006, 11:30 AM
  #43
Mike Rainbird
Caraholic
PM your address and I can at least send you those washers you lost
Old 01-09-2006, 11:38 AM
  #44
Porkie
Porkie's Avatar
Sometimes I am gald to be a non DIY, cheque book tuner
Old 01-09-2006, 11:49 AM
  #45
The DIVA
The DIVA's Avatar
Jay........
The copper washer method works perfectly mate,just use enough to space it correctly so it`s tight in the sender body and still tight into the billet.....
Alternatively you can cut the quip fitting down as per dougs pic and just fit it using a doughty washer either side......Oh and make sure you use a copper washer where the billet joins the pump as i can`t see one in your pic...
I have only used my method to drop the pump slightly into the tank swirl pot and i have tested it to 5 bar for an hour with no leaks whatsoever....
Old 01-09-2006, 12:01 PM
  #46
CozzyBrom
CozzyBrom's Avatar
Originally Posted by nightdavva
Jay........
diva i need more lessons
you dont use doughty washers your sposed to use viton washers
and also thats the wrong fittings you should use teflon fitting not rubber type
so cap in ya ass for both of you
Old 01-09-2006, 12:07 PM
  #47
The DIVA
The DIVA's Avatar
Jay........
Viton washers....Thats what i meant,just get a bit confused at my age...
I have had a link pipe made up to suit my fitting so there...
using overbraided PTFE with swaged fitting......
Old 01-09-2006, 12:13 PM
  #48
CozzyBrom
CozzyBrom's Avatar
viton seals are normally white or pale blue basicly a fuel retardent oring caged in a alloy washer
doughty seals go funny over time and can weep under presure although the fitting should seal on the jic cone presure wise and the seals just stop fuel leakin out the tank top
theres only one place i know that do the proper seals in jic sizes
Old 01-09-2006, 12:16 PM
  #49
Franco
Franco's Avatar
Yeah well maybe i'll listen to see what the experts say about mine & Robbies fittings.....
I'll have a look at sorting something over the weekend i think.
Ps Rob, there is a copper washer there now
Old 01-09-2006, 12:23 PM
  #50
CozzyBrom
CozzyBrom's Avatar
Jay........
i was on about the rubber hose fitting in the pic i aint seen your pic
Old 01-09-2006, 12:34 PM
  #51
Franco
Franco's Avatar
where's the fun in that Lee....
Old 01-09-2006, 12:49 PM
  #52
Mike Rainbird
Caraholic
I was going to say that "He actually gets to drive his car", but Lee hasn't seen his for longer than yours has been off the road .
Old 01-09-2006, 12:57 PM
  #53
kjc300
kjc300's Avatar
Not strictly fair - remember this????
Plus, I have NEVER seen Lee in a BROWN CARDIGAN!!
Old 01-09-2006, 01:46 PM
  #54
Mike Rainbird
Caraholic
Yeah, but look at the puzzled look on his face .
Old 01-09-2006, 02:17 PM
  #55
CozzyBrom
CozzyBrom's Avatar
omg mrs manning
katt your pics are the best i think the other one with shonky sitting on brunters tarmac was the best of all
Old 01-09-2006, 04:25 PM
  #56
kjc300
kjc300's Avatar
I do try Brom!!!
This one, you mean??
Old 11-09-2006, 07:41 AM
  #57
Franco
Franco's Avatar
Right managed to get some of these washers off the In Law over the weekend (He works for a tail lift company!)
I take it these are the correct washers to use for spacing the pump?!?
I think they're made of copper....... Not too sure.
Any good?????????????
Old 11-09-2006, 09:29 AM
  #58
Franco
Franco's Avatar
Heeeeeeeellllllllllllllllloooooooooooo
Anybody home!!
Old 11-09-2006, 10:05 AM
  #59
Billabong
Billabong's Avatar
Don't look like copper to me, but could be the pic's....
Old 11-09-2006, 10:11 AM
  #60
Franco
Franco's Avatar
A closer look Bill tells me you could be right!
Old 11-09-2006, 10:25 AM
  #61
AlexD
Post Miester !
AlexD's Avatar
Sorry to hyjack the post !
But whilst we are on the subject, how does that link to a Fuel Swirl Pot ???
I need to get one from somewhere, but not sure how to connect it..
Al......
Old 11-09-2006, 10:36 AM
  #62
Franco
Franco's Avatar
I think it goes from the fuel filter to a swirl pot, from there to another pump (044) then to the fuel rail............
Something like that!!
Funny feeling its from the filter to another pump, then the swirl pot now i've written that!
Old 11-09-2006, 12:01 PM
  #63
MONSTER
MONSTER's Avatar
Those washers look like they're made from steel Franco.
All I did was weld a boss the correct thickness onto the sender unit base then drilled it to fit the pump. Put a douty/dowty(sp) washer either side and it works a treat.
Old 12-09-2006, 08:16 AM
  #64
Franco
Franco's Avatar
Right thats idea's gone out of the window!
The washers do not fit, couple of mm out! Can anybody tell me where to get the washers pictured below on the left..........
Old 12-09-2006, 08:26 AM
  #65
MONSTER
MONSTER's Avatar
I got my washers from a place that reconditions steering racks etc
Old 12-09-2006, 08:41 AM
  #66
Franco
Franco's Avatar
Could i just use the 3 washers supplied by Mike R, then use a group of steel washers to space as required?
Using the 3 to finish off at the join's
Ie 1 at the top of the sender, one on the underside of the sender and the other at the end of the (normal) washer grouping??
Old 12-09-2006, 08:52 AM
  #67
MONSTER
MONSTER's Avatar
Wouldn't like to say mate, but when i got my washers from the steering rack place he had loads of different thicknesses, i really wouldn't trust a load of washers all piled on top of each other
Old 12-09-2006, 09:03 AM
  #68
Franco
Franco's Avatar
I just need a washer big enough to take the excess up with the Aeroquip fitting, so i might see if i can buy one thick washer to compensate.
Old 12-09-2006, 09:06 AM
  #69
MONSTER
MONSTER's Avatar
Old 12-09-2006, 09:14 AM
  #70
Franco
Franco's Avatar
We get there in the end mate!!
Maybe you'd better give me you're little siggy quote!
Old 12-09-2006, 09:16 AM
  #71
MONSTER
MONSTER's Avatar
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
kosienutter
31
22-08-2015 09:55 AM
3doorcozmess
21-08-2015 11:17 AM
dlwarrior
05-08-2015 10:19 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: Ahmed style fuel pump fitting kit.... MikeR maybe?
