ethanol
Old Aug 23, 2006 | 09:43 PM
Avinitlarge's Avatar
Avinitlarge
Default ethanol
Any idea where I can buy some ethanol for water injection?????
Old Aug 23, 2006 | 11:05 PM
abdr500's Avatar
abdr500
b&q i think
Old Aug 24, 2006 | 08:00 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Jus use Isopropyl Alcohol, works just as well, less likely to give you cancer, and easy to buy from Maplins etc as its used to clean computers etc etc
Old Aug 24, 2006 | 08:05 AM
Redkop's Avatar
Redkop
Model aircraft shops usually sell Ethanol.
Old Aug 27, 2006 | 11:56 AM
Avinitlarge
Thats good then, We use it at work
Old Aug 27, 2006 | 05:33 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
But handy if he swallows a load of anti-freeze coolant by mistake.
(Read the 100% water / antifreeze thread)
Old Aug 27, 2006 | 05:49 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Guys - i'm really hoping you're not using Ethanol in aquamist systems?
You need to be using Methanol... At a minimum amount to lubricate the pump shaft - at a greater volume if you're wanting the benefits of a meth/water mix...
Steve - IsoPropanol Alcohol (IPA) is ok
Old Aug 28, 2006 | 11:11 AM
Avinitlarge
So what is the best to use? Methanol, Ethanol or IPA?? And what % mix should it be??
Old Aug 28, 2006 | 01:52 PM
reality's Avatar
reality
Meth is typically want the internet sheep use!
Old Aug 28, 2006 | 02:14 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Didnt think it was an issue at alll on Aquamist pumps, could use straight water if want?
I know, hence my words
IIRC that scientificly itd be best (for performance reasons) to use Water, Methanol, and summat else (IPA maybe, I forget), as the heat absorbsion propertys of them all work kinda sequentially so work better than 1 type, even if the 1 type is the best as a single coolant.
Isothermic bollocks that I dont understand, was detailed stuff on the Aquamist forum that im not sure exists anymore.
Old Aug 28, 2006 | 02:17 PM
Fiecos Dan's Avatar
Fiecos Dan
in my Erl water inj i use curtain screen wash, as some have Methanal or Propanol in it, which is whats recommended by ERL.
And they Say MOST NOT use Ethanol, which is in most anti-freeze and some screen wash.
The way you can tell
Methanal and propanol is has a low Odour
Ethanol is high Odour
Old Aug 28, 2006 | 04:13 PM
Big Will_'s Avatar
Big Will_
A lot of kits are sold with race spec pumps - and on these you do need to put a dash of methanol in to lubricate the pump shaft.
Old Aug 28, 2006 | 04:26 PM
Avinitlarge
What about this then??
http://cgi.ebay.co.uk/Biodiesel-Meth...QQcmdZViewItem
Old Aug 28, 2006 | 04:36 PM
Big Will_'s Avatar
Big Will_
The less technical explanation goes along the lines of:
Dip your finger in aftershave/alcohol based spirits - then blow on it. Feels very cold for a short period of time.
Dip your finger in water - then blow on it - doesn't feel as cold, but it feels cooler for a lot longer.
By mixing methanol and water - you get the benefits of it being colder than water - and it stays cooler for longer.
Simple enough?
Old Aug 28, 2006 | 04:39 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Good point mate
But IIRC if you use water and 2or3 different chemicals (which ones escape me right now) you get an even bigger effect, or something
Old Aug 28, 2006 | 04:42 PM
Big Will_'s Avatar
Big Will_
True enough Steve - there are a handful of other 'ingredients' - but knowing that a percentage of aquamist users struggle to remember to fill the thing up with water - asking them to perform A Level chemistry tasks on a regular basis might prove tricky
Old Aug 28, 2006 | 04:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
ROFL
What sort of mix would be best you think? See soo many combos talked about, fuck knows whats best.
I know water is DEFFO cheaper than methanol tho
Old Aug 28, 2006 | 05:20 PM
Big Will_'s Avatar
Big Will_
Right - FFS don't any of you boys go trying this without a wideband lambda, datalogging and enough cash in your back pocket to rebuild an engine
But...
This mix should theoretically should work - it sees the introduction of Nitromethanol. The same fuel thats used in top fuel/funny cars.
Nitromethanol's chemical formula is CH3NO2, to compare, petrol is usually composed around C8H18.
If this was added to a H20 (Water) and CH3OH (Methanol) mixture of around 47% CH3OH to 45% H20 to compose the remaining 8% - running alongside maybe 2 grades colder plugs - then a gain should be seen.
The problem is trying to stop the Nitromethane seperating whilst mixed with the water and methanol - if this happens then one minute you'll be running rich, the next lean.
The other option involves looking into nitropropane - but we'll save that till i'm less hungover
Old Aug 28, 2006 | 06:05 PM
Big Will_'s Avatar
Big Will_
Oh - and the above mix might make your exhaust fumes ming a bit...
Not that you'll care i imagine
Old Aug 28, 2006 | 08:36 PM
Big Will_'s Avatar
Big Will_
This lot gone over your heads guys?
Old Aug 28, 2006 | 09:16 PM
reality's Avatar
reality
But with ample intercooling and the correct compression ratio, this shouldn't be necessary! But I digress
Old Aug 28, 2006 | 09:41 PM
Big Will_'s Avatar
Big Will_
True enough - i'd never suggest water injection be used to produce power in so much as using it as a det suppresant to achieve huge gains - more of a safety measure.
I've just sorted a setup out for a friend whereby his system is not only set to come in at 1 bar of boost - its set to only come on at 1 bar of boost where ACT's exceed 40 degrees...
The number of people who forget to fill their water injection tanks is scary - hence why the engine should still be safe to run even if the tank runs dry or a pipe blocks etc.
Old Aug 28, 2006 | 10:21 PM
Fiecos Dan's Avatar
Fiecos Dan
Thats common practice for water inj to be triggered by boost, act, and TPS.
i run my water inj setup using the washer tank, that way i can make sure i have water, whilist driving.
Old Aug 28, 2006 | 10:23 PM
Big Will_'s Avatar
Big Will_
Aye, on your map based systems - this was a modified 1S system
Old Aug 28, 2006 | 10:33 PM
Fiecos Dan's Avatar
Fiecos Dan
Old Aug 28, 2006 | 10:55 PM
leecavturbo's Avatar
leecavturbo
i have water injection as a safety measure only, i.e my car was mapped without WI so its safe without. but if a blocked injector or other fault occured, may put 1 or more cylinders at risk/lean, then the water should reduce any detonation to below damage stage and hopefully i will notice a performance problem and investigate before a rebuild is needed.
Old Aug 29, 2006 | 12:08 PM
Avinitlarge
Same here
Old Aug 29, 2006 | 12:16 PM
Shings's Avatar
Shings
I'm having my water injection mapped when my car goes in soon..
I was planing on just using water.
Any issues with thaT?
Jake
Old Aug 29, 2006 | 01:30 PM
Big Will_'s Avatar
Big Will_
Shings
Who manufactured it?
scoooby slayer
306
Jul 15, 2018 04:38 PM
turbotoaster
Feb 19, 2010 09:34 PM
pedro.caribe
Jan 21, 2010 01:03 PM
le-claw
Mar 24, 2006 08:22 AM
Paul Eggleton
12
Jan 18, 2006 09:04 PM
