how do you set the cam timing with adj pulleys?
MAD Carbon Cossie
Easy fella,
The dowell's should be in the old cams - unless this is for a Cossie ? In which case i'd guess your cam supplier !
As for the cam timing, your need a DTi gauge to do it properly ! Or use the old pulley, time it up & then swap the pullys over hoping the cams don't move with the outter ring loose on the vernier & then tighten everything after you put the belt on !
Good luck !
Jb
Good luck !
Jb
soz, forgot to say, they are for a zetec turbo.
there are no keys or dowls on the std ones, they are friction bolt things.
i have a data sheet saying that the inlet should be open 22 deg BTDC and close 62 ABDC
and the zorst should be open 62 BBDC and close 22 ATDC
i understand that bit, dunno how its done
i will be able to get hold of a DTI too
If you want to know how to work that out, read the essay i have spent many many many hours writing for next months Fast Ford magazine, and i still havent managed to get it to read how i want it to.
* Thats top of my head, use at your peril. lol
it said something like that lol
cheers stu, ill await to read your article!!!
just out of interest tho, is it pretty much the same as how the std zetecs are timed? there are still the cutouts in the backs of the cams for the 5mm thick plate to slot in.
cheers
cheers
Resident Wrestling Legend
from watching the bloke who builds things on discovery, you set the cam up to rear tdc and then fiddle with the dti and the timing disc that should come with the kit
but you need to know where tdc is set at first before you start to adjust otherwise it'll run like a bag of poo
on a tangent, didn't iread somewehre that blown motors don't need as much overlap as na engines?
MAD Carbon Cossie
Stu,
Can i just say your features in FF are the absolute mutz ! Full respect & i for one wanna thank you for doing it month after month, it must take up so much time & effort !
So thank you
Jb
So thank you
Jb
Dan, it doesnt matter what its at, you just need to make sure its moved 110 degrees from where it was at TDC to where the cam is at peak lift.
So if its starts at 89 degrees it ends at 199 degrees.
Obviously neater to do it at 0 though.
You just use a bit of wire or something bolted on as a reference on the dial.
Heres my mini when i was timing it in, i know its only got 1 cam and its in the block, but this was about 10 years ago and i wasnt into "twinks" at the time, lol, gives an idea though.
cheers chip, that helps
so with the pistons set to TDC and the dial at 0, wind it round 110 degrees and that should be fully open?
it says on the timing disc to put the DTI on the spring cap, and the data sheet is saying that the inlet should be open 22 deg BTDC and close 62 ABDC
is thatthe DTI should start to move down at 22 deg BTDC and be fully up at 62 deg ABDC?
i think i understand that
22 + 180 + 62 = 264, oh look its the duration!
BUT open how much?
different manufacturers quote duration at different number of thou lift.
IGNORE that bit, and just time it to 110 at full lift.
BUT open how much?
Dan, the 22 and 62 are basically telling you the specification of the camshaft, they arent relevant to instalation.
If you install it at 110, thats where they will end up anyway.
They are meaningless really though in terms lf REAL specification, well without knowing the lift too, hence why you cant compare different cams without more info.
Are those cams intended for a turbo or are those N/A Timing figures?
If they are N/A you will probably want to spin them apart by a couple of degrees but you need it on a dyno to do this really.
Dan, fit them as standard
Then check to see where they are timed.
It will NOT be correct, i guarentee it.
then loosen the pulleys (on the internal bolts not the centre loose on the cam) and adjust them.
Chip
full spec is as follows - they are BD10's but on zetec cams
INLET: open 22 deg, close 62, Dur 264, V/L 8.64mm (0.340") V/C 0.0., F/L 110, LATDC 1.05mm (0.041")
EXHAUST: open 62 deg, close 22, Dur 264, V/L 8.64mm (0.340"), V/C 0.0, F/L 110, LATDC 1.06mm (0.042")
i think i understand, im tired tho
Chip
Its NOT the full spec, its just some basics.
Dan, the best way to do them is this:
Get a dial gauge
Get the cam timing dial
Fit them standard
Buy me a big mac meal and i will pop up and time them in for you.
That assumes the same centreline as the standard cams, which is often not the case, it would put him in the right ballpark, but only to then set from, its NOT sufficient to make those sort of assumptions and could lead to piston to vlave contact on some cams (although not those i doubt on his pistons)
chip, i still have to build the bloody engine first, but rest assured, when the time comes ill give you a call
possibly do a little how to feature on it too
dojj, yes they have the slots, so ill go from there
is it worth doing a dummy build and putting some plasticine on the top of a piston and turning the cam over to see how close the valves get?
or not really worth it? i dont think the lift is any more than std really
i rememebr from my bmw days that there were different thickness head gaskets and certain engines needed different ones otherwise the valves would hit the pistons
if there was no way to check how much skim there was on the heads we'd have to bolt it all up and then spin it over by hand to see if they hit or not
so i'm sure there is a way to discover the hieght of the piston in the bore at tdc and the extent of the valve when it opens and then calculate where abouts you can time it in to minimise any chance of them hitting each other?
and if chip is correct (not that i'm doubting you chip ) and the centrelines aren't the same as the normal ford cams at least you know where to set up your cams for the opening/closing peaks too
ok, so if you have a longer duration then you might have to trial and error it, but you can always use one of them hight gauge things (can't rememebr what they're called but they are a big wieght with a ruller and a point on the end and you slide them up and down to see how high things are on a flat surface) to measure how far up the valves are going to go
are uyou useing hydraulic or solid lifters because that can also make a difference can't it?
Dan what i do if im not sure on clearance is put it together with no head gasket and turn it slowly round, if you get no contact then, you know you have 1mm clearance when the gasket is on, which gives some spare room to swing the verniers a little, but yeah plastigauge would be cool too.
If you are on hydraulics though they need to be pumped up which potentially they wont be though!
kosienutter
31
22-08-2015 09:55 AM
Zoggon
10-08-2015 10:39 AM
