pinking
Old Aug 1, 2006 | 08:51 AM
Cawood's Avatar
Cawood
Default pinking
what pinking all about?
set off in cossie this moring (only got it up last nite)
and when on full boost it was cutting/holding back and was jerky
is that pinking?
didn't do with yesterday or on test drive, whats the cause?
Old Aug 1, 2006 | 09:02 AM
KSA-Cossie's Avatar
KSA-Cossie
Not 100% sure but get ya sig changed cossie boy lol.
Old Aug 1, 2006 | 09:09 AM
carlo's Avatar
carlo
Could be overboosting what boost is it running & what spec? i.e injectors & chip....
Old Aug 1, 2006 | 09:12 AM
T28 RST's Avatar
T28 RST
Ok then
Default Re: pinking
Dave did you really need to tell us that
Old Aug 1, 2006 | 09:16 AM
KSA-Cossie's Avatar
KSA-Cossie
Old Aug 1, 2006 | 09:25 AM
Cawood's Avatar
Cawood
shit
Old Aug 1, 2006 | 09:26 AM
Cawood's Avatar
Cawood
not too sure on the spec
it peaks at 15psi then drops down to 10psi
the guy said it was stage 1
Old Aug 1, 2006 | 09:35 AM
KSA-Cossie's Avatar
KSA-Cossie
Check the plugs and gap dave,even better get a set of 071's from fords finis code 1120834 and gap them to 0.65mm.
Old Aug 1, 2006 | 09:52 AM
Cawood's Avatar
Cawood
i've got some of those spare at home
bought em for the turbo but ended up putting c59c's in
those 071s ok for cossies?
Old Aug 1, 2006 | 10:55 AM
BM08's Avatar
BM08
Pinking is when you get a labouring kinda sound when you put strain on the engine, i.e going up hill and putting your foot down, thats what i thought it was anyway my old clio rsi used to do it abit, the escort has never done it though
Old Aug 1, 2006 | 12:04 PM
abdr500's Avatar
abdr500
pinking sounds like to metal spoons taping togather
Old Aug 1, 2006 | 12:31 PM
Graceland's Avatar
Graceland
Team HOTHOT!
071s' are good for cossies yep. Make sure that you gap them properly tho
Where abouts in west yorkshire are you? If you need any help, pop over to mine and i'll cast my magic spanners over what you need doing
Old Aug 1, 2006 | 12:59 PM
Cawood's Avatar
Cawood
quality! thanks very much for the offer graceland
im over in keighley so not too far from you
these 071's have they changed the name or part no. as i ordered a set from fordpartsuk.co.uk (or whatever they're called)
n they send me some other ford jobbies saying they are the same just ford changed the code on them or summat
also cheers for the answers on pinking, what causes it?
Old Aug 1, 2006 | 01:02 PM
Graceland's Avatar
Graceland
Team HOTHOT!
sorted - straight up the A629 then
Get your plugs from Stu, I personally reccomend Denso IK31 Irridium - you won't break one of these babies
Old Aug 1, 2006 | 01:06 PM
Graceland's Avatar
Graceland
Team HOTHOT!
pinking or det can be caused by a few things - usually incorrect ignition timing or poor fuel grade
Old Aug 1, 2006 | 03:10 PM
dave120's Avatar
dave120
put optimax in it, thats the first thing id try
phone the guy you bought it off and ask him if he has had similar probs in the past, he might be able to point you in the right direction
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
1.9 xr2 on 40's
May 15, 2005 10:23 PM
jazraymcbeath
May 3, 2005 12:17 PM
Oranoco
27
Dec 13, 2004 01:09 PM
