Aghhhhh!!!! It's pinking again!
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
It's been suggested by a frined that the MAP sensor could be duff in the ECU. How can I check this? I don't want to fork out for a replacement if this won't cure it. Can I get my existing one repaired?
The car was left for 5 weeks with about ź of atank in it.
It's still pinking though after a put 20 quids worth of Optimax in it.
Keith it sounds like somebody shaking a bag of nuts and bolts vigorously under your bonnet.
Its normally caused by attempting to work the petrol too hard in some manner, which could be:
excessive compression (more on N/A cars)
excessive boost
too much ignition timing
poor quality fuel
excessive boost
poor quality fuel
excessive boost
poor quality fuel
excessive boost
poor quality fuel
Bloody hell mate, I haven't been on here for a couple of months, one of the last things I relpied to was one of your pinking threads...I come back and here you are again! This is a nightmare! Surely it's been in and out of so many places now, someone must know what the cause is? Maybe you are going to have to sacrifice a few psi to keep it at bay??
i'm guessing ignition timing problem.
unfortunately i have no idea how the E part of KE-Jet works so can't even begin to help
Originally Posted by cliff6732000
Colder air would make it LESS likely to pink
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Testing the future
if it's not crap fuel, and i wouldn't rule that out until you run the tank dry and fill up with what you know to be good fuel, then as jim says it must be a problem with the ignition timing not retarding (enough).
can you get a strobe timing light on it and check if the timing is changing? (you may have to fool the ecu into thinking that you have boost by pressurising the pipe going to the MAP sensor)
No Rich I always use Optimax and fill up either in Smallford or the one in St. Albans
I do run daft boost but I do have the 5th injector which has been checked and is working fine
I turned the boost down to just 11psi and it still pinks at the same point (as it comes on to full boost).
However.. its more likely to be either:
1) A split ECU signal hose.
2) A faulty ECU pressure transducer.
3) Lean fuelling for whatever reason.
4) Shit fuel.
4) Shit fuel.
4) Shit fuel.
2) Is that the MAP sensor in the ECU?
3) Checked and is fine and 5th injector working correctly
4) The time this has been happening for would seem unlikely.
It's cured and is fine for a day or so but then starts again
I think it needs a good stern talking to
If it's as intermittent as you say, I suppose I'd be thinking along the lines of an electrical fault, because a split hose is a split hose, and the other possibilities Stu mentioned aren't really intermittent problems are they?
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
Yes, some folk call it a map sensor, same thing really.
Id go for that option if its irregular pal.. OR full throttle switch intermittent, try and borrow one.![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
If it is the ECU can it be repaired or will I have to source a replacement one? Just thinking as even the last ones will be 13-14 years old now.
Ecu cant be repaired to my knowledge and yes, the newest is nearly 15yrs old im afraid.
focus rs 1672
denser air more fuel,no fuel there=det
send it off to stu mate for a test trust me
you can afford to be without it for a few days anyway, and at least then you know its 100%
also the ERST TPS is only a 3 position switch.... no throttle, some throttle, and full throttle... not a "proper" tps like you get on EFi that measures it exact
Sexy-RS
03-02-2005 05:14 PM
