Any Zetec Megasquirt Wiring Experts on here :-(
Old 10-07-2006, 10:22 AM
jason len
jason len's Avatar
Default Any Zetec Megasquirt Wiring Experts on here :-(
hi i have just bought a megasquirt v 2.2 to use on my 2.0 zetec.
i have looked at the wireing diagram and still cant figure out where each wire goes
p.s the wires are labled
pip-edis (red wire)
ground (black wire- but guess these connect to battery earth)
saw-edis (blue wire)
air-remp (green wire)
in5 # 344 (2 green wires)
fuel pump rly (black wire)
tps-sig (blue wire)
02 sensor (green wire)
nj # 1+2, (2 blue wires)
fidle relay (black wire)
coolant temp (red wire)
12v power (red wire)
tps 5v (green wire)
im still not 100% sure where they connect to ask i thought they would be color coded, im guess that picture is the block loom where the main ecu is? (under pasenger footwell)
do they just connect all on the loom where the ecu is?
anyone on here whos fitted on onto there zetec please help
Old 10-07-2006, 10:24 AM
SimonT
SimonT's Avatar
PM a guy called ASAD on www.fiestaturbo.com
he's a bit of a legend with megasquirt and has a massive guide post on the forum there.
HTH.
Old 10-07-2006, 10:26 AM
Ryan
Ryan's Avatar
seems very straight forward.
all of these will connect to the ECU, apart from
3-4 wires which are the ignition live and live feeds.
its wired very similar to the original setup
Old 10-07-2006, 10:28 AM
CosRush
CosRush's Avatar
Jason
As Ryan says, very straight forward really.
Is there any specifics you dont understand or is it all of it???
Old 10-07-2006, 10:38 AM
Garage19
Garage19's Avatar
I think you are confusing your self by trying to patch it into the standard loom.
It is simpler and you are better off making a new engine loom. You pretty much already have it labled and hanging off the ecu.
If you were closer i would pop round and give you a hand.
The PIP and SAW come from the EDIS unit so you will need the pin out for that as well which can be found here:
http://picasso.org/mjlj/?q=node/2
Old 10-07-2006, 11:24 AM
reality
reality's Avatar
I disagree.. it's a piece of piss to wire into the existing loom.. takes less than half an hour, if you do it properly! The big question is, what loom are you using? A zetec loom? If so, I have a wiring diagram for you.. I think I made a comparison chart once as it goes..
Old 10-07-2006, 11:26 AM
jason len
jason len's Avatar
yes its a zetec loom mate.
Old 10-07-2006, 11:58 AM
Avinitlarge
Avinitlarge's Avatar
I ripped the inside out of an old ECU, Made it into an adaptor break out box, My megasquirt is plug and play now
Old 10-07-2006, 12:22 PM
jason len
jason len's Avatar
reality have you got the wireig diagram mate?
Avinitlarge - that looks hard to do mate?
also where are you guys mounting your megasquirts? under the passenger footwell?
Old 10-07-2006, 06:00 PM
Avinitlarge
It was pretty easy to be honest, Im mounting my MS under the heater box, There is a nice space there
Old 10-07-2006, 07:04 PM
luke89
Team HOTHOT!
luke89's Avatar
jason len i also run mega squirt on my zetec and have a digram add me to msn and il send it over
Old 10-07-2006, 11:18 PM
jason len
jason len's Avatar
ok mate i added you
Old 11-07-2006, 02:15 PM
jason len
jason len's Avatar
has anyone got the wiring diagram for the zetec?
also guees im gona need to make the wires on squirt loom longer to fit in glovebox, anyone know what type wire i need from maplins?
Old 11-07-2006, 02:58 PM
reality
reality's Avatar
Here is a Mondeo one.. should be the same for a non-pats escort.. although it does appear to be for an internal-edis ecu.. i'll sort out another one tonight..
TPM961
15-01-2018 10:50 AM
IainRS1700T
25-09-2015 06:44 AM
focuspower
20-09-2015 03:51 AM
focuspower
19-09-2015 08:27 PM
BENJAMIN_21
Ford Fiesta
17-09-2015 08:58 AM
Quick Reply: Any Zetec Megasquirt Wiring Experts on here :-(
