NEW PRODUCT. ATTENTION ALL WEBER L8 & P8 OWNERS.
Old 25-07-2006, 10:46 AM
  #81
Dave Henshall
Dave Henshall's Avatar
go on stu,
spill the beans
what extra features etc are availaible... and prices to be retro fitted tou one of you old chips ...
Old 25-07-2006, 11:53 AM
  #82
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Ok, all the above will work as per normal except the following.
You will LOSE:
Boost valve duty cycle.
But you will gain:
Lambda correction %
Injection phasing position.
Idle valve duty cycle %...
And the ability to:
Reset The P8 properly.
Drive the following items at will:
DIS Cyl 1 and 4
DIS Cyl 2 and 3
Injectors
Fuel Pump
Idle valve
Boost Valve.
Be aware your P8 needs to be modified internally to allow this data to pass through to the connectors. This can be done here for £35.
The software for L8 and P8 datastreaming can be added to our old chips for £50 including delivery back to you next day. All new chips will already be thus equipped as std.
Old 25-07-2006, 01:16 PM
  #83
Dave Henshall
how will the boost work stu, will there now be no overboost facility in the chip , ie the escos lectron valve will work like a amal valve which will just open at a pre determined level...?
Old 25-07-2006, 01:22 PM
  #84
Originally Posted by Dave Henshall
how will the boost work Stu, will there now be no overboost facility in the chip , ie the escos lectron valve will work like a amal valve which will just open at a pre determined level...?
Sorry mate, you missunderstand my poor explanation.
The ability to monitor and datalog the boost valve in the RP Labs monitor will be lost. Your chip will function EXACTLY as it always did before.
Old 25-07-2006, 01:23 PM
  #85
Dave Henshall
Old 25-07-2006, 01:26 PM
  #86
Edited my reply again to make it even clearer, the heat is making me dumb
Old 25-07-2006, 09:49 PM
  #87
Old 26-07-2006, 05:30 PM
  #88
ECU Monitor Enthusiast
Stu,
Does the interface need external power/powered from the car ?
Old 26-07-2006, 10:40 PM
  #89
No simon.
Old 27-07-2006, 10:43 AM
  #90
Dave Henshall
does the interface come from the ecu (ie internal to the car) or does it go onto the loom and out to under the bonnet on a escos? would you have to splce into it it at the ecu end of the loom if you wanted it internal to the car withou running more cabled thorugh the bulk head?
Old 27-07-2006, 11:37 AM
  #91
Yes, it plugs into teh std escos diagnostic socket.
Old 27-07-2006, 01:03 PM
  #92
Dave Henshall
Old 04-08-2006, 07:09 AM
  #93
Old 07-09-2006, 06:18 AM
  #94
JanDK
JanDK's Avatar
A Q from a friend of mine who drives a 2wd..... does this IAW software go with L1 and L6???
Old 07-09-2006, 09:50 AM
  #95
JanDK
JanDK's Avatar
Cant seem to find minimum data for the laptop.. Stu????
Just got an old one, but maybe it is to small and slow.
Old 07-09-2006, 10:16 AM
  #96
foreigneRS
Testing the future
foreigneRS's Avatar
Stu is on holiday, as are RP Labs.
There should be little requirment for the laptop. Just enough space to install the software, and then any disk space left used to datalog. Windows 98 at a minimum I believe, but we should wait for confirmation from Stu.
Old 07-09-2006, 10:27 AM
  #97
JanDK
JanDK's Avatar
I will wait then
Old 07-09-2006, 03:32 PM
  #98
the original
the original's Avatar
I have been using this software for about a year now
my laptop is quite old 400MHz and 98SE
don't know if that helps
Old 08-09-2006, 04:38 AM
  #99
JanDK
JanDK's Avatar
hmm.. mine "new" laptop is old to.. pentium 233mhz i think... dont know more about it.. yet
Old 10-09-2006, 12:27 PM
  #100
A general comment....
Best make sure you get a PC/laptop with a built in RS232 serial port .
Unfortunately, nearly all new laptops now dont have them as standard.
Not all PC hardware is compatiable with most software.
Old 10-09-2006, 03:10 PM
  #101
JanDK
JanDK's Avatar
rs232 serial port.. will have a look at it.. thanks
Old 10-09-2006, 07:18 PM
  #102
foreigneRS
Testing the future
foreigneRS's Avatar
i have used this software with a pcmcia serial converter from brainbox
Old 11-09-2006, 07:19 AM
  #103
JanDK
JanDK's Avatar
What is that??? is it some big cinverterbox you need to take with you?
I see my serialport back on the laptop, but can not see if it is this or that...
Old 11-09-2006, 09:23 AM
  #104
foreigneRS
Testing the future
foreigneRS's Avatar
JanDK if you have a 9 pin serial port on your laptop, which you most probably will if it is over 5 years old, then you have the correct thing
the converter that i talk about is because my new laptop, and most new laptops tese days, do not have the serial port as most devices these days connect in other ways (bluetooth, usb, etc)
Old 11-09-2006, 10:45 AM
  #105
JanDK
JanDK's Avatar
Then I DO understand what we are talking about!!!! It is JUST a ordenary plain regular standard serial port I got one of those thats for sure I have seen it with my own eyes!
Thanks Nick...
In the end of the week I will have to laptop ready for carprojects then I just need to make a choice of who is making my new chip and ofcause MotorsportDevelopment to modd my ecu for this IAW software.. wuii
Old 05-10-2006, 08:44 AM
  #106
These are getting great reviews from all you that have bought them. thanks for your custom as i know a good few of you are on PF.
Old 06-11-2006, 05:54 PM
  #107
Old 13-11-2006, 08:17 PM
  #108
radiant red
radiant red's Avatar
anybody had experience with this yet
will it stop my gearbox breaking
seriously tho
Old 13-11-2006, 08:24 PM
  #109
Sadly not.
Old 13-11-2006, 08:27 PM
  #110
radiant red
i want the software........just need a laptop to go with it
pc looks a twat in my car
Old 17-12-2006, 03:21 PM
  #111
Dave Henshall
hmmm,
forgot about this, looking at the collins powerchip monitor, it does make this option quite cheap in comparison IF you already have access to a laptop,
in reality, i'd be best sending my complete ecu (chip installed) to have the mods done at msd, and buy the software and cable,
£ 35 ecu mod
£ 50 chip mod
£ 25 cable
£ 150 software
+ £ free laptop
= cheaper than the powerchips monitor
a quick q regarding the software security side....
would I have control over what the software is installed on, as in authenticate a passkey on a web server or email address, that allows me to change what laptop i run it on, as i will more than likely need it on multilpe machines, but only active on 1 at any one time, how fast/easy is it to swap licence keys fom one machine to another, and are there any limits to how many time you can swap it over..?
Old 21-12-2006, 01:11 PM
  #112
Dave Henshall
DIS Cyl 1 and 4
DIS Cyl 2 and 3
stu,
will that that be true for the secs driver board modded p8's aswell not just the pectel software that uses the p8's own driver..?
Old 21-12-2006, 01:32 PM
  #113
Yes, both utilise the same pins.
Incidentally, we can now drive the coils with our standard closed loop weber software as well if your ever interested...
Old 21-12-2006, 01:52 PM
  #114
Dave Henshall
so if i went to an aftermarket rev counter say, and i needed the room in the ecu for other boards i could remove the secs driver and set up the aftermarket tacho to read correctly by reading half the pulses from one side of the coilpack?
Old 21-12-2006, 02:02 PM
  #115
Hi,
Aftremarket will work with our driver you have now, again just set it to "DIS"
But yes, for examples sake; If you wanted to, you could remove and sell your driver and we could enable the distless option in your software whilst we were upgrading your softare to serial datastream output.
Old 21-12-2006, 02:07 PM
  #116
Dave Henshall
sridgett
01-10-2015 07:30 PM
3drRich
13-09-2015 07:32 PM
CrOwSoN15
14
03-09-2015 12:21 PM
TomPengelly
13
22-08-2015 06:38 PM
markk
15-08-2015 01:38 PM
Quick Reply: NEW PRODUCT. ATTENTION ALL WEBER L8 & P8 OWNERS.
