help needed pleeeeeeeeeese
Old Aug 11, 2004 | 11:00 PM
the strut brace's Avatar
the strut brace
Default help needed pleeeeeeeeeese
i think i know the prob, caqn anybody tell me how many turns a fuel regulater should have to be set about right
4wd fuel regulator , its been fucked about with, does anybody know if i turn alan key screw all the way clockwise or anticlockwise how many turns back or forward i need to turn it to be about right for normal use
need answer asap as im going to stus on fri
Old Aug 11, 2004 | 11:04 PM
cossiemen's Avatar
cossiemen
Whassup
Old Aug 11, 2004 | 11:20 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
question? why has the fuel pressure regulator been messed with?ie/ my saff is running greens and fuel pressure has been raised so that it doesnt run lean on high boost.if your car is standard,and you are looking for a base setting.warm the engine up to temp,turn the screw anticlockwise untill the engine starts to hunt,that means the mixture is weak.then turn it clockwise untill it idles evenly.drive to your nearest mot station and get the emmisions checked.if it is ok then drive to stu, but keep it off boost.might be a slow journey but cheaper than a melted piston
Old Aug 11, 2004 | 11:47 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Mate just go to your nearest MOT station and ask then nicely to put it on a CO machine and set it at 3-4% this will be fine to drive on then book it in with ENGINE ADVANTAGES to have it set up correctly
www.engine-advantages.co.uk
Old Aug 12, 2004 | 06:52 AM
the strut brace
thats the thing it wont start because its so far out, so cant go anywhere to get it checked, some plank at garage fucked around with it thinkin it would solve a different problem, now i just want to know how much to turn it to get it back to factory setting( ish)
Old Aug 12, 2004 | 07:02 AM
starturbo's Avatar
starturbo
Wish i could help you but its a bit like askin how long is a bit of string.sorry mate.
Old Aug 12, 2004 | 07:56 AM
Stu @ M Developments's Avatar
PassionFords Creator
The problem with the regs once fooked with is they tend to leak.
They have a hydraulic sealant applied to the threads in production and the tamperproof seal on top is also airtight for a reason. When over zealous mechanics wind it down to teh point it stops, they often nip the internal diaghragm and it becomes unreliable.
If this reg leaks i cannot do the work i need to do on friday without fitment of a new one. Its easy to test for a leak but the engine needs to be running for you to do so. Simply wet your finger and place it over the hole in the top, if you feel a slight "Sucking" on your finger, its FUBAR and needs replacing.
Old Aug 12, 2004 | 09:01 AM
Versus_Creations
Ask me a question!
Old Aug 12, 2004 | 03:05 PM
the strut brace
cheers stu, i know it hasbeen wound up ,down all fucking ways, ill have to persuade a nice freind to lend me his for the time being
by the way our lass has just said and i quote.....'can you not just get a new fubar like he says!'
she now feels stupid once i have explained what it means
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
