adjusting cossie fuel reg to work on a zetec?
Team HOTHOT!
right im not sure if i need to adjust my 2wd cossie fuel reg on my zetec engine on throttle bodies its running ST170 injecters im sure the car it come from was running stage 3
thanks
thanks
You need a fuel pressure gauge, the knowledge behind what pressure the ST170 is meant to run, what fuel flow you need to get the correct AFR for you engine, and also if your pump and wiring can handle what you ask of them
JoeyBoyden
04-01-2024 03:36 PM
kosienutter
31
22-08-2015 10:55 AM
CabrioTurbo
01-08-2015 12:04 PM
