Working with Liquid Nitrogen
Saw a thread about what everyone does for a job and i thought i would post this, i don't think it's that interesting anymore as i do it quite often but my brother thought it was cool so i thought i'd post a few pics.
Liquid nitrogen tank
Cryogenic hoses (stainless steel)
Nitrogen pumping unit
Control panel
Boost pump and stainless pipwork
"pot" or heat exchanger, converts liquid nitrogen to gas
High pressure side, nitrogen gas comes out this pipework, job done.
Control panel
If I understand, this kit above is used to turn the liquid into gas.
The gas is used for:
Nitrogen gas, N2, is produced by allowing liquid nitrogen, N2(l) (see below) to warm and evaporate. It has a wide variety of applications, including serving as a more inert replacement for air where oxidation is undesirable;
to preserve the freshness of packaged or bulk foods (by delaying rancidity and other forms of oxidative damage)
on top of liquid explosives for safety
in the production of electronic parts such as transistors, diodes, and integrated circuits
dried and pressurized, as a dielectric gas for high voltage equipment
in the manufacture of stainless steel
for filling automotive and aircraft tires[1] due to its inertness and lack of moisture or oxidative qualities, as opposed to air (though this is not necessary for consumer automobiles [2])
http://en.wikipedia.org/wiki/Nitrogen
The 60ft Launch King
We use Liquid nitrogen at work. Like Rogers it converted into Gas using heat/steam...
It's is pumped into our massive vessels and is known as a 'Purge'...
The nitrogen is forced into the vessels to remove any Oxygen... This prevents any ignition in the vessel when loading flammable liquids/resins. Reason why it's done is that nitrogen in a gas form is not flammable
Nice thread Roger, interesting pictures What pressure does it run at?
Nah i think i'll give it a miss Lol........
Toughy, yeah decided to stay after all, got a really good deal money wise out of it, but still thinking of moving on in the next few months, just got home yesterday.
In this case it's mainly used for what is called "gas lifting" of wells offshore, i.e displacing fliud in the well to nitrogen, basically flushing all the fluid out to encourage the well to flow, due to the Nitrogen gas being lighter than a column of fluid.
Smit, the liquid N2 tanks use are normally operated to about 2bar and can go upto about 5, but you never have them up that high, you do get higher pressure ones though. The output line in red and white can be anything upto 15,000 psi.
Originally Posted by Rhys
Dare you to stick your tounge on that!!! and take photo lol
JK12
33
26-04-2021 12:09 PM
borboyous
22-08-2015 11:17 AM
