ST150 and Warranty... your thoughts??
Old 31-05-2006, 08:40 PM
GTechR
GTechR's Avatar
Default ST150 and Warranty... your thoughts??
Right in a nutshell, a mate of mine has an ST150 it's been serviced at ford from day one, any probs, it's been straight back to ford...
A couple of weeks ago it developed a top end rattle... to the point where a mate of his who is a mechanic made him pull up on a motorway cuz he thought that it must have dumpped it's oil, when they checked it was at the full mark.
So yesterday he took it back to ford, they took it out for a 'test drive' and basically came back and told him it sounded like it was the little end that had gone, they said they would strip it under warranty, but if it was something not covered he would be looking at a £2k+ bill, now the car has literally in the last day or so just passed 8k.
Surely for an 8k engine, whatever is wrong with it, it should be covered?
Old 31-05-2006, 09:19 PM
UBster
UBster's Avatar
How old is the car?
Reason I bought a Honda 90,000 mile 3 year warranty on engine and gearbox..
Hope you friend doesn't have to pay a penny
Old 31-05-2006, 09:21 PM
bullsrs
bullsrs's Avatar
he should ask for an exhaustive list of what is not covered under warranty,The alternator on the girlfriends sportka was covered so i would think all engine parts would be
Old 31-05-2006, 09:24 PM
GTechR
GTechR's Avatar
Originally Posted by UBster
How old is the car?
Less than a year old mate...
Old 31-05-2006, 09:25 PM
GTechR
GTechR's Avatar
Very good idea...
Benni
Ban[B][/B]ned
Benni's Avatar
They might mean parts that are not coverd as they come under "Wear and tear".
Old 31-05-2006, 09:26 PM
GTechR
GTechR's Avatar
Yeah but £2k?
Old 31-05-2006, 09:29 PM
Benni
Ban[B][/B]ned
Benni's Avatar
All depends whats gone wrong i suppose, Dont know much about engines but if you ring ford customer service they will tell you.
Old 31-05-2006, 09:31 PM
UBster
UBster's Avatar
Unless they can prove your mate over revved the car like 3rd to 1st I can't see how it cannot be covered under warranty
If it was 5 years old with 90,000 on the clock I can see "wear and tear" but less than a year and 8k utter twats
Tell him to kick up a serious fuss!! I hope he's got a courtesy car as well?
Old 31-05-2006, 09:33 PM
Eagle
Super Moderator
PassionFord Gold Member (Male)
Super Moderator
Eagle's Avatar
under a year old i would be jumping up and down on the service mangers head screaming ....
contact ford direct and then go and sit the car outside of the dealership with a big sign saying its under a year old and its broken ..takes the pish..
Old 31-05-2006, 09:37 PM
GTechR
GTechR's Avatar
I dont think he has mate (courtesy car)
I told him to go direct to ford, bypass the dealer..
UBster
UBster's Avatar
Without a doubt!! ^ ^
If your mate wanted grief, engine failure and the expense of fixing a car he'd have bought an rs turbo, not a brand new ST 150!!!
Old 31-05-2006, 09:39 PM
Thrush
Irritating c........
Thrush's Avatar
Yeah but A) on a car under 8k miles?
and B) car is less than a year old, surely the UK statatory 1years gaurantee applies here?
UBster
UBster's Avatar
SHOCKING!
Mines been back in the last year for a slight squeek under the passenger seat occasionaly and a rattle from the gearstick surround, both times courtesy car for the day, used there fuel to get to work and back 40 mile trip, and come back to ass kissing and a valeted car.
As posted above service manager needs rather a lot of shouting out
Old 31-05-2006, 09:43 PM
Zetecfiesta
Zetecfiesta's Avatar
thats awful!!!
Old 31-05-2006, 09:46 PM
GTechR
GTechR's Avatar
Originally Posted by Zetecfiesta
thats awful!!!
It's the guy off our forum Sam...
Old 31-05-2006, 09:51 PM
TurboTuffy
TurboTuffy's Avatar
if the car has been mis-treated then maybe not covered , if looked after
then should be everything covered under the warrenty phone Ford Customer Services they will sort it out
Old 31-05-2006, 10:01 PM
Da Booga
Da Booga's Avatar
I'm sure i've read somewhere that the Ford garage can download "action replays" of the engines revs & driver inputs from the ECU.
I'm sure i've heard of instances where garages have refused engine warranty work due to the telemetry they've downloaded from the ECU showing mis-(or accidental) treatment such as fluffed gear changes as has been mentioned above resulting in over-revving.
If they can then it may be wise for your mate to prepare for the worst if he has done something that could have damaged the engine.
Hope I dreamed it though
GTechR
GTechR's Avatar
The car is mint mate... in no way has it been mistreated...
Old 31-05-2006, 10:20 PM
puddy
puddy's Avatar
All warranty details are in the owners handbooks supplied with the car.
It will only record an instance it see's a dtc with the ford wds diagnosis
eqpt.
You should be well covered under warranty tho,ain't even missed a
service yet!
puddy
Old 31-05-2006, 11:26 PM
M1CH43L
M1CH43L's Avatar
if every thing it stamped in the books and not modds to the engine then ur ok,, but ford are trying to save money throught the warrenty side ov things so b carefull if thay think theres some thing not quite right thay ull chuck the clame out!!! tis a ball ache but good luck
Old 31-05-2006, 11:55 PM
Andy_R
Andy_R's Avatar
Personaly I'd have an independant engineer verify that there is a knock and said engineers thoughts on the cause. Take some video footage showing the knock/noise etc.
If the dealer in question isnt playing ball then go elsewhere, I'd have thought there's plenty of Ford dealarships around about you/your m8?
If they then strip the engine and cant find anything you then have evidence that there was indeed a problem/knock/noise.
A pity that you have to go to the above measures but may well save you/your m8 any agro "if they cant find a problem".
Hope everything go's well.
Old 31-05-2006, 11:57 PM
Rab
Fucking superstar........
Rab's Avatar
SOunds like a citroen warranty
I'm sorry, we don't cover the rear beam on our warranty
Old 01-06-2006, 07:57 AM
angel24
angel24's Avatar
let them strip it, as under a year old, there will be very little not covered. Like others have said the instances for not being covered under warranty are in your manual, ie driver abuse, wear & tear, modifications, etc.
If they strip it down and inform you there will be a bill to pay, don't authorise the repair and get it touch with customer services. I am quite sure it wouldn't come to that.
cust serv 0845 8411111 (i think, from memory!)
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
gcfcos
59
06-10-2015 05:04 PM
Fezman1
02-10-2015 01:22 PM
Kiran1600E
11
02-10-2015 11:35 AM
gingeRS
17
02-10-2015 09:42 AM
Quick Reply: ST150 and Warranty... your thoughts??
