XR3i PROBLEMS - Please help
Old Aug 2, 2004 | 11:45 AM
McPikie's Avatar
McPikie
Default XR3i PROBLEMS - Please help
Ok, I am quite annoyed to say the least.
I bought an MFi XR3i last week that has been dry stored for 2 years. Tootled about in it for a while then got it on the rollers for a tune up. Needed new plugs and came out a little noisey. This turned out to be the water pump and 4 tappets collapsing at once.
OK, fixed that.
Then, next day it lost all oil pressure and started to tap its cock off. WTF i thought.
So, I towed it to the garage and left it with them to change the oil pump. They havent done it yet but have had it running to move it about etc etc and say its been running sweet since then
Now I'm confused. Could it be shit oil clogging the pump? Could the pump be failing intermittently or do they just go? What else could be causing this?
I am at a loss, but seriously fucked off at buying a car I cant drive.
Please help me.
Old Aug 2, 2004 | 12:05 PM
St3V3_C's Avatar
St3V3_C
I think you have a filter thing on the end of the oil pickup - this could be full of crap - I had a similar thing with a CVH I had a while ago, would go nice and quiet after a rest up, as the crap fell out I guess...
Old Aug 2, 2004 | 12:10 PM
McPikie's Avatar
McPikie
So should I whip the sump off and clean it all out?? Nice fresh oil and oil filter??
Old Aug 2, 2004 | 12:41 PM
McPikie's Avatar
McPikie
Bump for some more advice
Old Aug 2, 2004 | 12:52 PM
CabrioTurbo's Avatar
CabrioTurbo
yes mate the oil pick up pipe is more than liekly blocked on my old cab engine someone had 'gasket sealed' the sump and a LOAD of blue gasket stuff had got into the pickup pipe.. that engine died shortly after..
IMO the best thing would be to change the oil pump.. its a bit of a ball ache and a garage will prob charge you quite a bit.. but its one of the most vital things on the engine!.
I could prob change one in about an hour for you if you wanted.
You could just clean the pickup pipe but the thing is there will be all sorts of shit floating about and it will prob get blocked agian if the system isnt completely drained/cleaned
Old Aug 2, 2004 | 12:53 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Was it driving fine when you got it mate? I had a cvh do a similar thing, was like a good thrashing knackered it but the next day it was running as sweet as a nut!
Love your siggy btw!
Old Aug 2, 2004 | 12:55 PM
McPikie's Avatar
McPikie
Originally Posted by Zetec_mk4_XR3i
Was it driving fine when you got it mate? I had a cvh do a similar thing, was like a good thrashing knackered it but the next day it was running as sweet as a nut!!
EXACTLY wot it is mate. Confusing to fuck.
Phil, the garage are now "having a look" fucking gimps. I will give it a full change and clean.
Whats the best oil to use in a CVH??
Old Aug 2, 2004 | 01:00 PM
CabrioTurbo
mineral oil from halfords 10/40 orange bottle will be fine
Old Aug 2, 2004 | 01:03 PM
CabrioTurbo
to 'have a look' (ie a propper look) at the oil pump you need to remove the cambelt, pull the engine down, take the sump off, take the oil pump off.. that will take a retard about 1 1/2 hours max make sure they dont rape you on price mate
CheeRS
Phil
P.s any ideas regarding my post about insurance and this dickhead
Old Aug 2, 2004 | 01:09 PM
McPikie's Avatar
McPikie
Why you need to pull the engine down to look at the oil pump??
surely the sump just comes off if you unbolt it?
Oh, and regarding the insurance thing, go down and have a scout. if his car is there then its number 15 mate.
Give me all the details you've got and let me run it thru my "people finder"
Old Aug 2, 2004 | 01:15 PM
CabrioTurbo
lol because its impossible to remove the oil pump without lowering the engine.. there is only a little bit of clearance (ie about a inch ) which isnt enought to get the oil pump off the crank
Nobheads deatils (or what he wrote down anyway )
Tom Beryel, maybe Boyel or Boyle
4 portman Place,
greenfields Park.
(i assume this is in winsford as its about 5 mins away from where we were and he headed that way (he was also a scouser ))
Registration of his Vehicle N194 NHU
That is definately right as i looked on the rac checker thing and it said 1.4 fiat brava sx grey
stephenb4506
33
Oct 2, 2015 06:25 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
