leaking inlet maniiold gasket QQ please
Old 19-03-2006, 03:45 PM
abdr500
abdr500's Avatar
Default leaking inlet maniiold gasket QQ please
recently I have had a hesitation problem and a holding back problem I have now found the fault I hope. would a leaking inlet manifold gasket cause a hesitation problem oh its on a 2wd cosworth
Old 19-03-2006, 04:17 PM
Ollie.
Ollie.'s Avatar
Yes. I had a similar problem with my old 4x4 and once the new gasket was on it felt like a new car....
Old 19-03-2006, 04:36 PM
abdr500
abdr500's Avatar
Ollie6RS2
it sounds promising . my problem was i just lost power and had a hesatation problem wher it would jerk a few times befor picking up and even when it started going it didnt feel right .realy hope this is my problem
Old 19-03-2006, 05:39 PM
Basky
Basky's Avatar
has the tick over got any faster
Old 19-03-2006, 05:42 PM
Alvyn
Alvyn's Avatar
spray wd40 along the manifold to see if it IS leaking!
ps do NOT use carb cleaner
Old 19-03-2006, 06:01 PM
dave cos4x4
dave cos4x4's Avatar
when i ad a fooked inlet gasket it was popping when not accelerating.
little flames coming out the back too.
Old 19-03-2006, 06:03 PM
Ginge !
just finding my feet
Ginge !'s Avatar
revs would be higher though if it was leaking ?[/code]
Staffi
Staffi's Avatar
I get flames
Old 19-03-2006, 06:21 PM
Alvyn
Alvyn's Avatar
NOT neccessarily
Old 19-03-2006, 06:58 PM
dave cos4x4
was not revving high on mine.
Old 19-03-2006, 09:53 PM
abdr500
abdr500's Avatar
my one is popping a little. and some times whistle and my boost has also dropped from 2bar to 1.6 I sprayed crab cleaner on my suspected area and the revs went up .a new gasket and a plenum spacer would do me nice
Old 19-03-2006, 09:59 PM
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
I use carb cleaner to check for inlet leaks as above if its leaking revs pick up
Never done no harm on cars, but me bike was addicted to it lol
Bri.
Old 19-03-2006, 10:04 PM
abdr500
abdr500's Avatar
Alvyn
why no carb cleaner ive never had a problem
Old 19-03-2006, 10:18 PM
Alvyn
Alvyn's Avatar
Originally Posted by abdr500
Alvyn
because it COULD catch on fire due to the ignition leads etc which are under the manifold
Old 19-03-2006, 10:32 PM
abdr500
abdr500's Avatar
Alvyn
i c
Old 21-03-2006, 08:40 PM
abdr500
abdr500's Avatar
changed gasket and it fixed my air leak. but the hesitation problem is still ther it does it low rev and when flat out other wise if just crusing the its fine its like i get to pops then fine agine every time i lift of the throttel
Old 21-03-2006, 08:57 PM
Basky
Basky's Avatar
have you checked the plugs
running an air leak can cause it to run rich there for fowl your plugs
Old 21-03-2006, 09:00 PM
GUZZLER
GUZZLER's Avatar
why don't you take the car somewhere to be tuned?
Old 21-03-2006, 09:03 PM
abdr500
abdr500's Avatar
GUZZLER
because that has all ready be done befor i did the conversion i have booked it in to go back but only for a set up to be sure its ok. this only started happining only last week its some thing stupid but need to sorte it. the plugs are perfect in coulor Basky
Old 21-03-2006, 09:08 PM
Basky
Basky's Avatar
wot about the gap size?
Old 21-03-2006, 09:11 PM
abdr500
abdr500's Avatar
Basky
i gaped them to see if it helps it did stop the back fireing a littel but problem is still ther
the tps is my suspect back not 100% suer what do you think
Old 21-03-2006, 09:12 PM
abdr500
abdr500's Avatar
ther about 5 month old plugs
Old 21-03-2006, 09:18 PM
Basky
Basky's Avatar
personally i would try new plugs then look else where
cossie ,s do tend to spit plugs especially when run rich
wot gap have you tried
Old 21-03-2006, 09:21 PM
abdr500
abdr500's Avatar
0.8 and 0.6
Old 21-03-2006, 09:25 PM
Basky
Basky's Avatar
try a new set
Old 21-03-2006, 09:35 PM
MARCOSWORTH
MARCOSWORTH's Avatar
If the gasket is bad or gone you should see it,does it run bad or not as it should on idle?
Old 21-03-2006, 09:41 PM
abdr500
abdr500's Avatar
MARCOSWORTH
i have changed the gasket i solved one problem but the main fault is still ther i am gona try new plugs and go from ther
Old 21-03-2006, 09:56 PM
leecavturbo
leecavturbo's Avatar
i had this and it caused detonation on the 2 cylinders concerned ,piston/ring damage found after
Old 21-03-2006, 09:58 PM
abdr500
abdr500's Avatar
leecavturbo
so what was it
Old 22-03-2006, 04:56 AM
MARCOSWORTH
MARCOSWORTH
I see,didnt read all
Old 27-03-2006, 10:35 PM
Basky
Basky's Avatar
did you manage to sort out the hesitation
Old 27-03-2006, 10:37 PM
abdr500
abdr500's Avatar
Basky yes it was my tps
Old 28-03-2006, 06:38 AM
Basky
Basky's Avatar
nice one
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: leaking inlet maniiold gasket QQ please
