help needed!!
Old Mar 15, 2006 | 09:01 AM
Twellsie's Avatar
Twellsie
Default help needed!!
Got home last night to find out my cossie is pissing water, after a bit of pooking around it looks as if its coming off the bit under the thermostat housing (it looks removeable and has a pulley on it). Can any one tell me what this part is, is it easy to fix and if its a garage job is there any quick fixes to enable me to drive it to the garage???
thanks in advance
Rich
(very disgruntled cossie owner)
Old Mar 15, 2006 | 09:02 AM
DaveEscos's Avatar
DaveEscos
water pump
short stumpy hose connects it to the thermostat housing
easy to replace, therm off job
Old Mar 15, 2006 | 09:03 AM
Graceland's Avatar
Graceland
Team HOTHOT!
that'll be your water pump then.
if its a 4wd one, replace the little rubber hose between the pump and thermostat housing at the same time
Old Mar 15, 2006 | 09:07 AM
Twellsie's Avatar
Twellsie
how does it come off? do you have to take the belt off??
Old Mar 15, 2006 | 09:15 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
yes take the belt off,its on a spring loaded tensioner.
Old Mar 15, 2006 | 09:27 AM
Twellsie's Avatar
Twellsie
thanks i will go and get one then
Old Mar 15, 2006 | 01:05 PM
Twellsie's Avatar
Twellsie
i cannot get the belt to release, is there a knack to it??
Old Mar 15, 2006 | 10:15 PM
Graceland's Avatar
Graceland
Team HOTHOT!
15mm spanner on the bolthead on the tensioner, then turn clockwise, while holding the tensioner down with one hand, remove belt with another
but i think you need to take it to a garage if you are doing anything more than changing a belt - i can see this ending in tears
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
