AP vs Alcon 6 Paddle...
Just fitted my AP clutch as the alcon lasted 5 mins...
gone from a standard cover & Alcon 6 paddle
To a
Heavy Duty AP cover and AP 6 paddle
The AP one feel's much better than the previous and grip's very nice....defo an improvement as the car change's gear better too
Shame the car doesn't in this heat
To a
Don't you think that this post is a bit premature until you have finalised testing . Will look a bit silly if in three days time you start posting how it has also only lasted "five minutes" . You should at least wait until it has surpassed the Alcon in longevity .
And I'm not biased, as I sell both clutches .
Originally Posted by le-claw
Mike, i am not posting about how long it lasts, was a post about feel, grip and gearchange.
All is better with the AP
Keep us posted if it outlasts the Alcon .
That is my point, as the AP one is only rated to 385Nm (284lb/ft) .
Its rated at about 380lb/ft i think.....
Re: AP vs Alcon 6 Paddle...
To a
To a
as for the figures ap quote for there torque ratings, we all know that there very conservative.
mark
Mark,
I completely mis-read that, I always thought he was running the full kit . In that case, Dingly you spaz, you should be looking at the OE cover, as Ford switched to Sachs several years ago (from AP Borg & Beck) and these are barely able to take stage 1 power, so I am not surprised with your findings .
well my experiance has always been in fitting a pukka kit, not mix and match, they are built together for a reason, out of interest what was the problem with the complete alcon setup ?
its all irrelevant to me as i have a twin plate ap, so dont have any clutch problems. just trying to see what people get away with.
If one thing is better for an application then its better - regardless of mix n match IMHO....if it works it works - simple init
The alcon didn't last long thats all, as soon as we up the power it turns to shit LOL
my alcon stick open for a split second longer than it should at gear changes over 7k.
mark found this out when mapping the car and mentioned that he had had this prob before.
Ap cover will fix it.
Originally Posted by B11GNS
I have an alcon 6 paddle with a ford cover (ap, not sachs) and its more than up to the job, my car is over 390 lbs/ft
Originally Posted by Bosch-Man
I run the alcon 6 paddle with the alcon heavy duty cover as Mike told me Nice and light..surperb...in Ebay style A+++++++++
i ran the complete alcon kit with cable operation...(not a plate and an oe cover) right up until i fitted the 7 speed and had no complaints at all and it was used for loads of launches with around 550bhp
i also breifly tried an ap cover and it was back out in under a week...heavy as fuck
how much to change to hydraulic?
My tests so far are all positive....
I have a hydraulic Clutch, but one using the original release fork, which is not idea but cheaper than the central push item.
I have tried this with...
Alcon Cover and Plate
Borg&beck Cover and Alcon Plate
Heavy Duty AP with HD AP 6 paddle
The AP so far is the better to launch and for general feeling, will have to see how like it lasts but so far this AP one is mint.
Sorry mike, forgot to look on the box for the part number as i was busy blowing boost hose's off 2 degree's inlet sure does make the car a bit dangerous
