my alcon 6 paddle is slipping
i have a 6 paddle alcon in my zetec turbo using an xr2i flywheel and alcon pressure plate
it's done 2k miles in running in mode limited to 4k rpm then mapped to 10psi limited to 5.5k rpm for another 1000 miles and then a bar of boost to 7k rpm and 2k miles at this boost
i drive it like a normal car every day rarely using boost unless i see a scooby! and dont whellspin and do silly things like that
i will add i was propper giving it some after a scoob in 2nd and accidently whacked it in 5th and it overpowerd the clutch and this has happend 3 times once was at santa pod
i just upped the boost to 18psi to map the fueling and the fucking clutch slips
the clutch all of a sudden slips and bites hard when u let off the throttle
and done 6 santa pod launches best was 101mph in 14.3 secs
thats the history of the clutch!
i thought alcon clutches was meant to be the bollox but sees like i spent over 300 quid on somthing not up to the job
i will have to add that the clutch didnt work properly because the bite was right at the bottom of the peddle so i had to put a spacer on the cable to max out the ratchet and make the bite point higher
aparently i need to fit another clutch peddal to get around this
so is it bolloxed or not good enough?
i thought when u went for a paddle clutch u were ment to swop to the manual adjustment cltuch pedal is it out of a mk5 escort or something as it was more suited to the paddle clutch
Maybe you've glazed the material of the clutch by overheating it - you might find it comes back again slowly if you treat it well. If you plan on abusing the clutch like you have been, you might be better with a AP 4-paddle.
lol @ abuse
i wouldnt rearly call that abuse i have been nice to the Ł300 clutch
only got accdentaly abused when i put it in the wrong gear but it would of thought it should of gripped instead of slipped @ 200bhp no matter what i throw at it
I've got the alcon 6 paddel with alcon cover and some times get slip.
I think when its time is up i will get the centre plate re linned and use a heavier cover.
I think its the Alcon covers that are to blame.
Super Moderator
its not the clutch thats at fault its the car its in,a paddle clutch is not suitable for road use as there designed for competition use,one fast lauch and than thats it your away.not stopping and starting in traffic,think how many times you actually press yoru clutch and hold it on the biting point.
if you look at the design of the paddle clutch the friction area is only a matter of mm thick this sirface will wear like anyother clutch but 10 times quicker as there less material there.
I have seen road cars get through 3 plates a year,yes you need the clutch to hold big power but you have to pay the price for it wearing out fast
I know Sunny had the same issue with his Alcon 6 paddle in his FRST so maybe the Alcon 6 paddle for the RST is not as strong as the cossie item. With AP 4 paddle Sunny's car was much better and didnt slip.
HTH
Bobby
HTH
Bobby
HTH
Bobby
HTH
Bobby
Norris Motorsport
As Sunny has mentioned avoid Alcon 6 paddles for the RST, anything around 250bhp and upwards slip.
You can use the alcon 6 paddle plate with an AP 3560-1 cover and that improves matters up to say 300bhp.
Beyond 300bhp and up to 350 bhp you will need to run the AP 4 paddle plate and AP3560-1 cover. This is what we used on Oli's S1 in the recent thrashes and it just about held on to 350bhp. Now we have raised the power the 4paddle AP is slipping leaving the only route beyond 350bhp as a proper twin plate with hyraulic setup.
With the twin plate setup there are a lot of options so make sure you are advised correctly on this setup and buy a clutch suitable for your needs.
HTH
Bobby
HTH
Bobby
i bought a helix six paddle and the dam thing wont even hold 10psi let aloan the 28psi i want to run plus 70shot of nos.
Or you could go for one of these badboys that would be more than up for the job.
Just make sure you get sold the right spline unlike what happened to me first time round.
Originally Posted by zvhturbo
Where did you get your exhaust manifold Turboboss?
Originally Posted by R4N S S
Seany - car is looking good dude - oh and you aint gonna beat me and Geoff matey
Originally Posted by * Rudey *
turboboss was your car a 1900 at some point? sure i remeber reading the feature hows the new power compare dude as my last was a nutty 1900 cant wait to get on with mine
then i changed to a roller bearing turbo and tubular manifold which made 311bhp @5960rpm & 296fbt
now my current spec built by zoo motorsport mapped by karl norris
zoo motorsport built 2.0zvh eagle steel rods je pistons 7:8:1 compression ratio
David Newman custom cam
Pumaracing 45mm valve race spec larger insert cvh head with custom double valve springs
Gt25/40r 0.64 dual roller bearing turbo Simpsons race exhausts tubular manifold hks filter
Zoo three inch exhaust system from the turbo back
Zoo turbo pre-rad and oil cooler with remote oil filter
Zoo spoon style inlet manifold with 45mm ram jets
Grs fm cooler grs 520mm rad
Uprated escort cosworth fuel pump
S8 ecu running coil pack, closed loop lamba, water injection
750cc injectors
Zoo group a engine mounts and gearbox cradle.
Transmission
Cts stage two plus gearbox with shot peened & polished gears
Helix six paddle clutch extra heavy duty cover
Zoo hydraulic clutch
Brakes
Hi-spec Wilwood four pot calipers 300mm discs alloy bells
Hi-spec 300mm rear brake conversion alloy bells
Zoo Wilwood pedal box conversion triple master cylinders brake biased valve
Suspension
Avo coilovers
Zoo rose jointed adjustable rear beam
Zoo adjustable rose jointed lower arms for camber & castor
so looks like i have to go twin plate paddle clutch will have to handle over 400fbt
fookin in hell Sean thats an impressive spec list
even if you are gonna lose to the cossie possee
@ the moment i've not got a hope in hell due to my clutch slipping but once brom fixed my problem with a twin plate paddle
i'm going to hunt you down
im pleased this thread has dug up some usful information
this company http://www.kellysearch.co.uk/gb-company-92029264.html
can referb my clutch for Ł90 and skim flywheel and pressure plate for about 30 quid
and there about 1 mile from my house
would you recomend whiping the clutchf/lywheel off and geting it re-done?
Guest
Posts: n/a
750cc injectors
Transmission
Brakes
Suspension
Avo coilovers
rudey what are you having done @ zoo.... how far away are you from finishing your car , there goner be so many big power fwd cars on the road next year...
mrviper i'm using a helix six paddle but cant run anymore then 13psi due to clutch slip so goner go twin plate paddle...
i havent had much luck with alcon six paddles either. Not even running loads of torque as its na but i do drive it daily. Didnt have slipping problems but the spring pooped out the clutch
we had a fiesta rst with a 1.8 zvh running 210bhp and only 300nm
And he had a alcon 6 padle and it only lasted 4000 miles
and he needed a fly wheel and plate
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
