Please help me with Garage roof, im going INSANE
Ill explain from the begining, since buying a house it came with a detached single concrete prefab garage with a metal roof.All was fine till the weather turned cold and the metal roof frosted over inside then when it thored it dripped all over my car.
My first attempt at curing this was to fit a tube heat on a thermostat that came on at 6 degrees and went off at 6.1 degrees.
Come the next cold night it did the same again so i bought a load of kingspan and fitted that to the roof but that didnt work either
Will a wood and felt roof cure this problem and im lossing sleep over my car getting wet???
Would that not cause the roof to rust if i trap the water inbetween the felt?
Having read your last post again I'd be more worried about the upper side rusting due to rain fallin on it rather than condensation on the underside , surely it's treated and galvanised?
What I did with a steel roof garage was put a wooden ceiling on bottom of trusses with some wall insulation on top of it but not touching the steel. Also a bit of ventilation between the space. Never had any issues in almost twenty years.
Or plenty of wood shavings between the two lol, plenty of soakage
I have thought of that but all the water will just drip on the insulation. Had sombody out today to measure up for a complete new wood/felt roof
Lift the roof an put the felt underneath, it's a few quid a roll and it's what all new roofs are done with and what I did mine with recently and not a drip, so dry when I brush the floor the new concrete floor is still powdery
The condensation is caused by warm air hitting the cold sheets so insulation and ventilation between insulation and roof will stop it so nothing to drop on the insulation, I have two garages done same way and have never had any issues,
A little update here. My new dehumidifier arived from 4air this morning so i went straight to the garage and plugged it in.
I left it for 10-15 mins and there a nice little puddle of water in the tank
And in its new home
And in its new home
Any joy with the dehumidifier? Only other thing i'd say is warm up the moist air to(warm air holds moisture better). Also, as a previous reply, make sure nothing is soaking through the roof.
A similar post is here https://passionford.com/forum/genera...er-winter.html - i think you posted in to??
The kingspan will do sweet FA if there is no air gap between the roof and the kingspan. If the eves are open (vented) run a breather felt on the underside of the tin and so it runs off the external side of the eves then put the kingspan back up. Leave 25mm between the tin and breather felt and the felt and kingspan. This may be impossible without taking the roof off, but with out seeing it, it hard to tell. You may be able to pin it to the underside of the rafters?
I had a similar problem with mine getting condensation and dripping all over the electrics, so, i managed to get hold of some secondhand polycarbonate sheets (the stuff for conservatory roofs) and screwed that to the underside of the roof joists and sealed all the gaps from the inside, that way the heat was contained inside thegarage rather than going up to the joists and metal roof, i also made sure the were plenty of vents above the polycarb layer to allow airflow below the metal roof, havent had a drip since.
I keep checking the polycarb and so far no signs of any drips on it yet after several years
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
