help needed compomotive mo6 wheel nuts?
dose anyone know what wheel nuts are needed to fit the compomotive mo6s ? as its only my locking nut that fits
thanks all
thanks all
Are there different tapers for diff wheels?
I'm asking cause I brought a set of group a longer nuts, the ones when you can put them with standard length studs and to get them tight they kinda cut into the inserts, so thinking if I have the wrong ones...
got the wheels on now , had to use 3mm spacers on the front to clear the coilover , but I have ordered some extended studs too so the nuts have more stud to go on , so hopefully they should be here soon , also I will be needing some wider tyres as I thought I could maybe get away with the 215 .... yea I am not into the euro look things so I will need some 235s
removal and the pros and cons
air gun needed and steel washers for the pull
extended studs are a bastard to fit
JoeyBoyden
04-01-2024 02:36 PM
Mad_Mat
Alloy wheels and ICE for sale
28-08-2015 10:03 PM
