Dodgy rev counter and missfiring?
On my 2wd cosworth im getting a problem with missfires and erractic rev counter. My rev counter doesnt work at all for about the first five mins and the car runs fine. Then once the rev counter starts working its jumping all over the place and then the missfires start when driving around normally. Then suddenly the rev counter works fine and there are no missfires for a few mins and then goes erratic again and missfires start etc etc.
Does this sound like the phase sensor or phase sensor wiring being intermitant?
It has got a coilpack conversion aswell, could it be the coilpack going down?
It could be the rev counter causing the problem, ie causing both the dodgy readings and the misfire, as it is connected to the coil.
Maybe disconnect the tacho and do some driving, if the misfires gone the tacho is the faulty item, I have had this on cars inc sierra before with the tacho going down.
As above, had a similar issue, traced it to the wiring in the engine bay on the bulkhead where the loom connects (there are 3 multiplugs i think). Anyway my SECS monitor showed that the ECU was reading double the actual RPM, and hence the ECU "thought" it was hitting the limiter all the time when it was only hitting about 3500 rpm. Give the wires a wiggle and see if it cures the rpm counter fault, maybe a biut crude but atleast it'll give you an indea where to start, and it's a really common problem.
Well i've done a wiggle test on all the wires a re-positioned them slightly but no differnt. Ill start looking at sensors next week as its going back in the garage now.
Thanks for all your suggestions, I was thinking also it could be any of the above. Ill let you know how I get on!
Mine still done this before I took it to bit's to restore it,
I tried 2 different sets of clocks in it,
GrpA coil then a New Genuine Ford one,
New HT leads and coil lead,
New Ignition amplifier,
Checked all 3 of the mutliplugs,
New Phase sensor
New dizzy cap and arm,
and it's still the same.
I had a missfire around 4500-5000rpm and the needle would bounce right off the clock.
On idle it used to jump a little, no more than 500rpm either side....
I'm putting all new everything on the car whilst I'm rebuilding it and I'm gonna replace the wiring from the coil to the rev counter and the crank sensor, the only things I hav'nt done yet....
New Phase sensor
New Phase sensor
New Phase sensor
New Phase sensor
New Phase sensor
That's be a shagged engine loom or the CPS then
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
I had this problem when I bought my cossie and replaced the phase sensor but eventually traced it to the multiplugs at the back of the engine bay. The connectors get filled with dirt. I totally removed the connectors and soldered the loom together and it's completely cured it. Only took about half an hour. That was about 4 years ago and never had a problem with it since. Hope you get it sorted.
I put a new CPS on this morning and it didnt make a difference. Will prob try a phase sensor next and check all the wiring loom and the earths. Will give it another go on my next days off.
Don't mention ze Vor
I'm having a similar problem.
Rev counter goes mad, but only under boost. If I accelerate through the revs with only a little throttle it's fine. Didn't notice any misfire yet but I'm only running std power.
My mate had the same problem and it was the coil. Any other ideas? 4x4 Saff (YBJ) btw.
![Thumbs up](https://passionford.com/forum/mages/icons/icon14.gif)
I had same problem with my 2WD Sapph. Tried 4 different rev counters,all doing the same thing. Took it to a local auto elictrician(cornwall).It turned out to be a faulty suppressor near the coil.He cut it out,reconnected the wires and solved the problem.The suppressor is black. Best of luck D.B.
Time for an update. Put a scope on the ecu and check all the sensors were working correctly which they were and all continuity is good. Now the rev counter has stopped working all together and it hasnt miss fired once. I have taken the rev counter out and tested it using a signal generator and it worked fine. Also tried different ign amps aswell and no change.
Because its got the MSD wasted spark fitted, the green wire that would trigger the rev counter from the coil is no longer connected and hasnt been for some time. Where does the rev counter now get its signal/pulse from? I just cant get my head around it, its probably so simple Im overlooking it.
Dangerous Brian - Im not sure if the suppressor is still part of my circuit as the wasted spark is fitted.
Yeah the msd wasted spark loom connects to 21 and 26 and from what I have worked out, these are the trigger to the ignition amps 1 and 2 driven from the wasted spark driver. I have checked then for continuity and they are ok and I also connected pin 21 directly to the back of the rev counter expecting it to half read but it was dead.
Ill send you an email Brian.
Right, I know what Im going to do now, Im just going to make my own loom for the rev counter as I mocked one up last night and it worked first time. Nice simple easy fix and just disconnect all the old wires that are not needed. Thanks for all your suggestions and dangerous brian, I probably wont be giving you a call at the weekend! cheers.
Wish i had of read this earleir i am having the exact same problems apart from i am not running coil packs.
So far i have changed.
Cap and rotor arm.
Tryed different spark plugs.
Thanks to loader a different coil.
Brand new phase sensor.
Also my rev counter only works some times but i have a missfire even when its not working. But when it does work it jumps all over the place.
Oh and Adam send me ya number bud could do with a ctach up at some point.
Cap and rotor arm.
[quote=sierrsteve1980;5372619]Wish i had of read this earleir i am having the exact same problems apart from i am not running coil packs.
Cap and rotor arm.
Oh and Adam send me ya number bud could do with a ctach up at some point.[/quote
sent you a pm !!!
Cap and rotor arm.
sent you a pm !!!
Yes and no. I made up my own loom taken from each side of the coilpack using a couple of diodes and wired it directly to the rev counter. Started the engine and it worked spot on, then after about 30secs it started fluctuating and then stopped. Took the clocks out and plugged it into my other sierra and the rev counter works fine. I compared all the connections from car to car and the only difference is that at idle the voltage on the rev counter trigger is 10V in my sierra running standard coil, but at idle in the cosworth its 16V. Not too sure if this is making something on the gauge cut out after a few seconds due to to much voltage? Because the rev counter works when I start the engine everytime then stops. Its a nightmare!!
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
cozzy jeff
14-08-2015 05:46 PM
