How many of you guys run 400+ bhp on std. MT75 box?
Old 02-01-2011, 11:33 AM
Rockhound
Rockhound's Avatar
Default How many of you guys run 400+ bhp on std. MT75 box?
And how long time have you been doing that without issues?
Personally i think the durability and lifespan of the gearbox, has a lot to do with the way the car is driven, but i would like to hear your experience about this.
Maybe i'm totally wrong? I have not covered enough miles in my own car to have any experience with this, but i am aware of the problems i could or should i say will get? when running 400-450 ish on a standard box. So honestly i'm thinking about running with a lower boostpressure until i can afford a decent gearkit upgrade.
Old 02-01-2011, 12:00 PM
KSA-Cossie
KSA-Cossie's Avatar
A lot to do with how it's mapped and driven imo,mine will be over 400 once mapped although I have quaiffe front and rear diffs fitted.
Old 02-01-2011, 12:37 PM
xr_craig
xr_craig's Avatar
I'm less than 400 and mine is slightly dodgy into 3rd. I'd say it depends on how many miles the box has on it and how it's been used more than the power level to a certain extent.
Old 02-01-2011, 02:10 PM
StephanCosworth
StephanCosworth's Avatar
I'm running around 380 bhp / 450 Nm torque and no problems or strange noises. Don't know how the previous owner driven the car, but I'm always very carefull while shifting and NO launching starts and everything is still working.
Beside this I'm also thinking about a stronger gearkit for my future plans.
Old 02-01-2011, 02:36 PM
graham c
graham c's Avatar
my old ecoz ran 400 hp and woz fine as long as you dont launch it. am going skyline box in my mk1 soon
Old 02-01-2011, 05:29 PM
Turbosimpsons
Turbosimpsons's Avatar
mine ran for years on totaly standard box and diffs. i only had it a week and changed it to 2wd. they drive so much better as 2wd.
Old 02-01-2011, 05:33 PM
Trev_rev
Trev_rev's Avatar
3 gearboxs a year i do.....should really spend the money on a decent box to take it,
but i do drive it hard and some track........
Old 02-01-2011, 09:36 PM
Moonstone Mo
Moonstone Mo's Avatar
Now then Trev been a while happy new year mate
p.s sorry for the hijack of the thread
Old 02-01-2011, 09:48 PM
james kiely
james kiely's Avatar
would shotpeening and super finishing the gearkit be a good enough compromise for 450bhp
Old 02-01-2011, 10:27 PM
paddyrs
paddyrs's Avatar
there only good for about 380 so i was told by cts
Old 03-01-2011, 08:31 AM
OAP Pete
OAP Pete's Avatar
Default OAPPete
My 3Door has excess 400 BHP... Quife Diff...standard Box...but with Quick shift.. Paddle Clutch.. all OK !.
Old 03-01-2011, 08:35 AM
Staffi
Staffi's Avatar
Different gearbox Pete..
Trev_rev
Trev_rev's Avatar
is your 3dr converted to 4wd......
beat me to it ......
Old 03-01-2011, 08:46 AM
Dicko&Vacant
Dicko&Vacant's Avatar
I ran mine on a t38 for 6mth then then went to a t4 with sweedish plenum etc car made 478hp and used it like that for another 6-7mth all with standard box and diffs and was fine.
Old 03-01-2011, 11:55 AM
Rockhound
Rockhound's Avatar
Thanks for all the replys. I can see theres a lot of different opinions about this topic.
Old 03-01-2011, 12:58 PM
OAP Pete
OAP Pete's Avatar
Default OAPPete
In the spec for Car says "T5" take it thats different then... 4x4 then T75.. Thans info. Pete
Old 03-01-2011, 01:37 PM
Staffi
Staffi's Avatar
Yes Pete, T5 box is on 2wd cossies.. i.e ours and 2wd saffs..
Old 03-01-2011, 02:55 PM
richcos 92
richcos 92's Avatar
I had a re-built standard box. Fitted a gt30 turbo look it down the road and 2nd gear went BANG. Bit the bullet it the end and got a Fix-it gear kit built up by Bara. Not cheap but it's stayed in one piece so far.Just the diffs to do now
Old 03-01-2011, 04:00 PM
paddyrs
paddyrs's Avatar
mine is 375bhp and 375ft/lb and i bust my box about 2 weeks ago 3d went bang when i was given her a lot of beans tho
Old 03-01-2011, 10:17 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
over 400 for 4 years and always had std trans....the box went bang not long after but the car had been running a t34.....this box has been in for over 3 years and (fingers x'd) is fine ...........ps it's the ft/lbs that kill the box but mine's doing ok at 390ft/lbs
Old 04-01-2011, 12:50 AM
ASHCOSSIE
ASHCOSSIE's Avatar
i run 345bhp and 400lb done 8 lanches at pod last time i was there and rear diff went but box still good, done 18000 miles that i no off. And no problems so far
Old 04-01-2011, 07:29 AM
charlie luciano
charlie luciano's Avatar
420 BHP/400 FT/LBS of torque in my car, standard box and diffs in my car with a front diff strengthening plate fitted, just over a year since I done my power upgrade, I had a t34.48 previously which made 326BHP/312 FT/LBS of torque and I blew two boxes
a lot of it is down to how the car is driven, if you drive any cosworth like an animal sooner rather than later something will break, standing launches at the pod will kill the diffs and large boost spikes will kill the gearbox particulaly 3rd gear.
as already said its not bhp that kills 4x4 boxes its the ft/lbs of torque that does it, any thing more than 300 ft/lbs of torque and you're living on borrowed time.
Big tooth gear kit is what is needed if you have a big power 4x4 to drive the car to its full potential, one will be going in my car as soon as the funds are available to me until then its applying a bit of TLC whenever I drive the car
Luciano
Old 04-01-2011, 09:07 AM
Rockhound
Rockhound's Avatar
Luciano
That sounds very similar to what i expectet. I will order a semi cut big tooth gearkit too within a year or two, and until then i will just be carefull like you are. But my engine is not assembled yet and it it all brand new. So in the springtime and summer this year i have a break-in period ahead of me where i will only drive
Old 04-01-2011, 09:11 AM
D16PJM
D16PJM's Avatar
my old 3dr was converted to 4X4 and had 417bhp and no trouble although i have been told i drive like miss daisy.
Pete
Chas
21-09-2015 08:57 PM
c20tbo
17-08-2015 10:19 PM
yawiejon
15
09-08-2015 06:36 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: How many of you guys run 400+ bhp on std. MT75 box?
