pinto and Yb blocks the same?
is a 205 block the same in a pinto as it is in the Cosworth YB?
im not fussed with internals, just the basic bare block
Can i take a bare 205 block from a pinto and use it to build a new bottom end for my YB 2wd?
Yes you can without a doubt, you can also use the 200 block if you want.
All that happened with the "yb" blocks were they were plucked off the standard pinto production line based purely on bore sizes, they were microscopically smaller so the walls of the bores were microscopically thicker, the bores were numbered 1 to 4 with 1 being the smallest(thickest bore walls), that's why most yb have the numbers 2/2/2/2 stamped by the dizzy hole, not all 2/2/2/2, my own one is 2/3/3/2.
So use with confidence any 205 block, the 200 block has a thicker skirt around the base of the block, as the sump and of course the 4wd diff etc are supported off this.
3dr Cosworth owner
as said above they were all destined for 2.0 sierra's and were just hand picked as the better blocks of the batch and they went into the cosworth. Heard of people using blacks from transits etc, think they were a 203 block
As said above they were just selected for there bore tolerance, there is one other minor difference that being the 'Selected ones' have YB then a four digit number on the from of the block. The Transit block talked of above is a 202 block which some people use.
Martin
Martin
They ARE NOT THE SAME!!!
I was shown a batch of pintos blocks side by side and you can see that the cast webbing is much much more beefy on some types than others, the strongest being a YB 205 block.
you can build all the Cosworth parts into them, but they aren't as strong. I couldn't tell you at what bhp/lb/ft they'd become a liability though.
The ones with the thicker casting are 200 blocks, oddly enough you're talking complete rubbish.
The pinto or T88 to give it it's correct name was codenamed YAA and was 100% PURE pinto, but don't listen to me read read Mario Illien's comments, which went on to state
" comapred with the T88/pinto engine from which the new turbocharged YB evolved almost everything was changed, except fro the cylinder block, front cover and jackshaft, except for these parts all was new.
For those that don't know Mario was the man behind the engineering of the YB, I've a suspicion he knew what was used as he used it and asked for it.
LOL as said thats utter rubbish!
The 205 as we have said is just a Pinto block nothing more nothing less, this is all the YB is anyway just a jumped up Pinto, the 205 is NOT the strongest block either.
The YAA which was seen by accident when on a visit to Cosworth to look at Formula 1 engine, Stewart Turner asked Keith whats that? To which the reply was "Thats a Pinto with a cylinder head conversion, we believe there is enough demand for it to put into production as a performance part" Nothing more was said. Turbocharging was then thrown in by Stewart's legendry comment whilst consuming a ploughmens lunch at a pub. To be specific "If we turbo charge your Pinto with the 16V head and put it into a Sierra Rover won't win another race" and so the YB was born.
205 blocks can't handle big power, it's a lottery some have run 500HP some have cracked at less, also you can't long stud these.
The 200 block as said is alot stronger, of course I am excluding the YBD 205.
That book your quoting is a good read as well!
Martin
Martin
there s me thinkin you knew a bit about the old fords lol
tbh i think luck has alot to do with them staying together, my supposingly strong 200 block cracked at 420 bhp
Cake lover!
Martin
Martin
There were a number of evolutions of the 205 block, the best at the time being the version fitted in the Sierra 2 litre iS (If I remember correctly they had 205 in bigger numbers cast into the side of the block than the other 205 types) and it was from these ones that the cossie blocks were selected based on optimum bore size of 2222 as stated above.
ill be running little more than 300bhp when shes finished so the block should be fine
anymore than that and i think my RWD will become a bit TOO arse end happy!
chowfornow
14
05-01-2019 09:01 PM
