pic of ecu?
Old 14-04-2010 | 02:09 PM
first_cosworth's Avatar
first_cosworth
Default pic of ecu?
hi there,i wonder if anybody can help me ,do any of you guys have a pic of an opened ecu in a 4x4 cosworth?
trying to establish if my car is chipped ,or not?
this is my ecu.
cheers guys.
Old 14-04-2010 | 04:06 PM
jon@work's Avatar
jon@work
I doubt it's standard as the Pectel board isn't standard. The "window" on the chip needs to be covered asap.
Old 14-04-2010 | 05:28 PM
first_cosworth
sorry,please forgive my daftness but i see the window on the chip,why would it be like that,and what difference does pectel make?
the car has a missfire you see,so was going to get a new map sensor,as everything else checks out,so i thought i would check the ecu in case it had a chip etc.
Old 14-04-2010 | 05:32 PM
martysmartie's Avatar
martysmartie
What he ^^ said also about the window that will wipe the memory if not convered!
Martin
Old 14-04-2010 | 05:46 PM
first_cosworth
right guys,understand i have to cover the window of that chip,does any body recognise the chip,and sorry to be dim but what does pectel mean for me?
Old 14-04-2010 | 05:59 PM
oldford's Avatar
oldford
There's nothing to recognize on the Eprom, that's the problem.
The Pectel board also means that it's encrypted and not everybody can read and modify the mapping.
Old 14-04-2010 | 06:04 PM
first_cosworth
ok so where do i go from here?
cheers guys
Old 14-04-2010 | 06:44 PM
jon@work's Avatar
jon@work
Do you know if the chip is OK for your engine spec? Has it ever run well? If you don't know the spec of the chip, then your options are limited - either bin the chip and buy another, or get a tuner to read the contents and tell you what it was written for.
Old 14-04-2010 | 06:50 PM
first_cosworth
hi
no i do not know if the chip is suitable,my car has,different actuator,exhaust,filter and green injectors.
the car appears to need a map sensor,but took a pic of the ecu and it seems to have asked more questions than answered!
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
NZWINRZ
Ford Focus RS
28-01-2020 09:24 PM
DixieTheKid
14-09-2015 09:04 PM
Tank Mike
14-09-2015 03:56 PM
Quick Reply: pic of ecu?
